Old 23-03-2014, 04:18 AM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default Au Fairlane both low beams H/L not working
Hey i just need some help
Both my low beams have stopped working
High beams still work though
Switched over the green relay in location 9 with relay 11
Still nothing
checked all fuses and wiring still looks good
Any more suggestions if so please can you help
Thank you so much
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2014, 09:12 AM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: Au Fairlane both low beams H/L not working
Have you tried actually changing the globes?
A quick check of the circuit is to swap the plugs over on the lights themselves. As both low and high are H7 just put the low beam plugs on the high beam globes and turn them on to see if they work. Then you'll know for sure if it's the globes or the circuit.
MINE- AUII Forte
Old 26-03-2014, 09:26 AM   #3
NCII40
XR6T BA 2002
NCII40's Avatar
Thank you so much for the reply and your help
Seemed both bulbs blew at the same time
All fixed now
Could find why both went like that
XR6T 2002 BA
Old 26-03-2014, 06:57 PM   #4
Bushbasher
Bushbasher's Avatar
I dare say they didn't both blow together but probably within a few days of each other. If you put a pair of globes in of reasonable quality then you can be pretty sure the QC is reliable so it has to be expected that both globes will come to the end of their natural life at roughly the same time. When I blow one globe I usually go and buy a fresh pair and the remaining globe that still works goes in the glove box as an emergency spare.
Bushbasher
MINE- AUII Forte
Old 26-03-2014, 09:41 PM   #5
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks again
Much appreciated
your spot on having some spare in the glove box
Definitely would save the high beam drive home again
XR6T 2002 BA
