Old 08-12-2013, 11:42 AM   #1
Lajon
Default Au lane driver's door trim removal
G'day i have a series 1 au lane and i need to get the driver's side door trim off so i can access the window as i need to replace/fix the clips on the bottom of the window... i have removed most of the door trim however, i can't seem to undo the plug that connects to the mirror control and also the door button has a metal rod attached to it...what do i do about that?
thanks
Lajon is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2013, 12:20 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: Au lane driver's door trim removal
Push the tab on the connector while pushing the plug in then wiggle and pull the connector.
If you need to you can use a screw driver to push the tab.
The lock button should pull out.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
