Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 03-10-2013, 06:25 PM   #1
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Default Boost A Pump
Bluepower for a long time has been using the Boost A pump (BAP) to solve many fuel related issues with tuned boosted cars. The beauty of the BAP is that it can be fitted to any car with ease.
Most commonly the BAP has been used to solve the fuel issues with the new 5.0 S/C Falcons where the fuel trends to lean off at high RPM. This is where the BAP come into play. By Using a BAP there is no need to upgrade the in-tank pump to increase fuel pressure and supply
Standard fuel systems will have a voltage difference depending on voltage loads Eg Head lights, Stereo etc. these can changes the fuel pressure to the injectors and causes the engine to run lean.
How it works.
Wired into the factory wiring loom the BAP steps up the voltage to the fuel pump to keep a constant voltage from 12V all the way up to 17.5V, this is triggered by a boost pressure switch that only turns on after 5 Psi so you don’t get the over fuelling issues at idle caused by aftermarket fuel pumps.
The Boost A pump is so good that even Shelby fit them to every Super Snake that rolls of the factory floor.
Fitting diagrams are also included with the kits for easy installation
Booster A Pump Street Single channel kit is $435 posted anywhere in Australia
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2013, 05:00 PM   #2
Theo@BluePower
Bluepower
Default Re: Boost A Pump
We also have been using the Dual channel Boost A Pump on Twin 044 setups on E85 and the like. This has been a massive advantage by not being forced to set up a 3rd 044 pump.
The Dual channel Boost A Pump can run up to 20V with a 40 Amp draw
Bluepower website
03 9305 3000
Old 10-10-2013, 10:47 PM   #3
ratter
ratter's Avatar
Look forward to testing one of these shortly on Bels car
Pit Lane Performance
Old 16-10-2013, 03:30 PM   #4
Theo@BluePower
Bluepower
Just to give you some more information on this product after a heap of inquires
These units can be fitted to any make or model and is very simple to install
Boost A Pump 40Amp - Naturally Aspirated Engine $435 posted
Boost A Pump 40Amp - Forced Induction Engine $400 posted
Boost A Spark - Naturally Aspirated Engine $375 posted
Boost A Spark - Forced Induction Engine $425 posted
Spark is one of the critical processes in the cycle of any internal combustion engine.
In many circumstances OEM systems are fine, however when higher cylinder pressures exist either through camshaft timing, compression or boost the spark event can be hampered by these engaging factors.
It is the closing of plug gaps and the like that can induce poor low rpm burning. Closing plug gaps on an FI setup is something that we historically have HAD to do. With a high quality spark amplifier like an old school MSD unit or a Kenne Bell Boost-a-spark closing plug gaps is a thing of the past.
Here is some detailed Tech info on the Boost A Pump from KB
http://www.kennebell.net/KBWebsite/C...elpumptech.pdf
Bluepower website
03 9305 3000
Old 18-11-2013, 06:59 PM   #5
ratter
ratter's Avatar
I hope Chris and Theo don't mind me posting this here, but I carried out some testing on their Boost-A-Pump today
http://www.fordforums.com.au/showthr...11#post4939611
Old 19-11-2013, 06:10 PM   #6
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
hi guy's is this booster the same as Herrod's one?
2014 FG2 Falcon XR6 luxury in Black, - New toy 2022 HD Lowrider S 124hp/136flb's
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2013, 09:07 PM   #7
BOOSTEDGAZ
When in doubt-MORE BOOST!
BOOSTEDGAZ's Avatar
This is the American Kenne Bell unit, top unit but not plug and play like Herrods one is
PROUD TO CARRY ON THE ALUMNATOR's LEGACY
PROUD TO FLY THE BLUE STREAK FLAG HERE IN NZ!!!
[SIGPIC][/SIGPIC]
BOOSTEDGAZ is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2013, 09:05 AM   #8
40RDT
40RDT's Avatar
How hard is the boost a pump and boost a spark to install?
FG XR6T Ute
300rwkw
40RDT is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2013, 10:30 AM   #9
Bluepower
KenneBell Australia
Bluepower's Avatar
Hi GTGAZ,
this thread is about a proven performer that has been around for many years and has all the runs on the board, and is just as plug and play as the competitors product, which has no history in Australia.
Beware of imitations.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2013, 10:34 AM   #10
Theo@BluePower
Bluepower
The Boost A Pump is very easy to install, there is two locations it can be installed. one of behind the glove box and the other is under the passenger seat.
Earth is simple to get from any bolt mounted to metal near the unit.
Power comes from the factory fuel pump wire which we cut and place bullet terminals on so it can be easy By-Passed or returned to stock. One end of the wire with the fuse connection is connected to the OEM fuel pump wire and the boosted power wire is then connected to the other end of the OEM wire that runs to the fuel pump.
Next you set up the controller box which we leave hanging down during tuning so we have easy access tot he unit.( once tuning is finished we relocate the unit behind the glove box.
On Turbo/Supercharged car there is a Pressure switch that comes with the kit that triggers the extra voltage only when needed. This we place in the engine bay and is run of the vacuum line near the fuel pressure regulator.
The unit is limited to 17V as we don't want any issues with the factory wiring being overloaded. This will cause very expensive wiring loom replacement.
"0" on the dial is standard voltage all the way to "100" is 17Volts
We offer over the phone tech support with all our products.
Dave from CPV in Mackay has been using a Boost-a-pump in his FG F6 for the last 2 years trouble free, Standard fitment in Shelby Super Snake, so you know its good!!
Bluepower website
03 9305 3000
Old 20-11-2013, 11:45 AM   #11
40RDT
40RDT's Avatar
Thanks Theo
What about the boost a spark? Have you had success with those also? Does it work off a pressure switch too?
Do you think they would both fit behind the glove box? I've got two amps under passenger seat unfortunately
FG XR6T Ute
300rwkw
Old 20-11-2013, 03:38 PM   #12
Theo@BluePower
Bluepower
Both BAS and BAP work of pressure switch and you can use the same one if you are running both.
The Boost A Spark we mount under the dash near the fuse box. again it same fitting as the BAP. you just need to find the correct wire.
We went from 500Kw to almost 550Kw just with a BAS on a blown 5.4 with a Kenne Bell running 15 Psi. being able to open spark plugs gaps up make a massive difference both in idle/Low RPM and when the BAS kick's in at high RPM as we get a much faster burn in the cylinder which makes all the extra power.
There is no "Plug and Play" power amp's on the market. both kits currently in Australia take the same time to wire in. There is no loom adaptor to just plug into. both kits still can be returned to stock easy.
Bluepower website
03 9305 3000
Old 21-11-2013, 06:51 AM   #13
preying on lions
good stuff guys I can see myself coming over for a holiday and picking one or two of these up- also would be good to check out the ford factory before it closes, cheers Geoff
Old 11-12-2013, 02:57 PM   #14
BFXR8
if I installed both of these would the car need to be retuned ?
BFXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2013, 03:21 PM   #15
Theo@BluePower
Bluepower
That would depend on the type of car and mods on it.. generally if you put mods on a car then retuning will give you gains
Bluepower website
03 9305 3000
