15-09-2013, 08:18 PM | #1 | ||
Jeep/Mercedes Technician
My mums AU is having issues with the ac not turning on and i have narrowed it down to a break in the earth wiring or the ecu, me and the boys at work are looking at it being a bad ecu as the car also has a rough idle and weird shifts in the trans ever since the car got wet inside at a car storage place earlier in the year
So it is a series 3 forte and my car is a series 2 forte, just wondering if i can just whip my ecu out and into her car to make sure that it is definately the ecu and not a wiring issue? Will there be any issues or will it just be a simple straight swap and see job? Thanks for any help guys really appreciated
The Ride FGX XR8, Silhouette, Manual, 500HP, 940NM, Tune, 71mm Pulley, KPM Intercooler, BMC Twin Air Filter |
16-09-2013, 08:54 AM | #2 | ||
Au Falcon = Mr Reliable
Go for it you can only try, they are basically the same.
cheers, Maka
16-09-2013, 10:09 AM | #3 | ||
RIP...
Series 2-3 ECU are compatible with each other, however you won't be able to just do a quick swap because of smartshield.
To swap ECU's with smartshield you need to visit a Ford dealer to do a pats reset or an auto sparky who can do it, though they seem to rare.
. Oval Everywhere... |
31-05-2023, 01:13 PM | #4 | |||
XR8 Thanks. |
31-05-2023, 02:36 PM | #5 | |||
Regular...with metamusal
good gold mine - but to answer your question ...... i know with the 6 cylinder versions the series 1 does not swap into the series 2/3, so i'm presuming the V8's are the same as well .. |
31-05-2023, 04:47 PM | #6 | |||
Good luck finding one though..............
Proud owner of the ugliest Ford ever made |
