Old 27-08-2013, 07:16 AM   #1
Mulga
Mulga's Avatar
Default Smoke coming from oil filler cap
I was checking around the engine bay after a recent drive and was surprised at the amount of heat from the engine bay.....I know it's pretty tight in the bay and there seems to be little room for the heat to dissipate.
I removed the engine filler cap and noticed smoke coming from the filler spout (engine was not running) and also from the spout after I removed the dipstick
Has anyone else noticed this???
Just to confirm that the car was not driven hard prior to me checking this and the check took place within a few minutes after the car was turned off.
Mulga is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 07:28 AM   #2
WILDB
WILDB's Avatar
Default Re: Smoke coming from oil filler cap
That's pretty normal for all vehicles, not just the ST.
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 07:55 AM   #3
Mulga
Mulga's Avatar
I know it's chalk and cheese, but I've checked our territory and it does not smoke......anyway thanks for the reply.
Old 27-08-2013, 09:29 AM   #4
hazrd
Red Rocket...
hazrd's Avatar
All of my previous cars have done it, I think you would be fine that being said, you could still ask your dealer if it still worries you, just for peace of mind.
2012 Colorado Red Focus ST
hazrd is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 05:51 PM   #5
WILDB
WILDB's Avatar
My XR6T did it, so did the XR5. It's just vapour from the oil.
It's all good, no need to worry about it.
Old 27-08-2013, 07:39 PM   #6
pajoda
pajoda's Avatar
All cars do it, in years gone by the crankcase use to ventilate to atmosphere, and they had a pipe that use to spew everything onto the road and into the air. The PCV valve and 27A if I can recall stopped all that and it was all forced back into the intake to be burnt. I would not be concerned either.
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 10:37 PM   #7
marg99
So this is the cause of dirty throttle bodys!
marg99 is online now   Reply With Quote Multi-Quote with this Post
Old 28-08-2013, 09:15 AM   #8
pajoda
pajoda's Avatar
Unsure what point it enters the intake system in our cars. Anywhere from the valve seats back to the entry point is exposed in direct injection engines and the amount depends on how much each engine generates.
2018 Ford Focus RS
