21-08-2013, 10:32 AM | #1 | ||
Hi all. I have to replace my steering rack in my XR8. It got a ton of play and starting to stick in places and is getting worse. Can I use one off a 6cyl or are they different. Thanks in advance.
Ps the ball joints and control arm bushes have been replaced so it has to be the rack. |
21-08-2013, 11:03 AM | #2 | ||
could it just be the rack ends? you can pick up a set with boots and tei rod ends for $50 on eBay. to answer your question, yes a 6 cylinder one is the same
[SIGPIC][/SIGPIC]
21-08-2013, 11:13 AM | #3 | ||
have a set of boots and rack ends in the shed (it is leaking into the boots). It seems more than that but, it has a sticky spot just off centre and when you turn it it like jolts a little. I don't really trust the car in corners and it is a shame as it is a fun car to drive in twisty stuff. Found a v8 one on ebay for 200 exchange so might just get that.
21-08-2013, 11:20 AM | #4 | ||
ok sounds more like a terminal rack problem I. you look around there are plenty of well priced recos on EBay some don't even need an exchange . I personally would rather spend a few extra $ on a reco than on a used one that is an unknown quantity.
[SIGPIC][/SIGPIC]
22-08-2013, 01:33 PM | #5 | ||
i did a bit of a rebuild on my xr6 rack some years ago, if you want to have a squiz at the parts, i did it from top to bottom, it was fairly fiddly and i spent a bit of time innovating tools to do the job, after looking back on it for the effort involved to me a c/o looks to be well worth it.
http://www.fordforums.com.au/showthr...g+rack+rebuild |
27-08-2013, 05:52 PM | #6 | ||
Yes you can use a 6cyl rack, but need something to fill the hole where the power steering pressure switch goes as v8's dont have the hole.
If you want more inches ,stroke it!! |
