Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Hi. New to AFF - bear with me. I have a 2010 FG XT, 6 speed auto. Warranty expires in two months. I travel a short distance (2 km) to work in freezing Canberra winters so transmission would not fully warm up. I am looking at using a PWR air/oil cooler to bypass the standard Ford transmission unit and avoid the "Milkshake" problem.
1. Has anyone had very cold weather (down to -8 deg) experience using the air/oil cooler? -over what time frame (years)? 2. If so, has there been any ill effects on the ZF 6HP26 transmission. 3. If I DIY, avoid any spillage, then totally fill the cooler and lines with the correct fluid, do I need to have a specialist go through the procedure for "topping up" the transmission? (Car has done 65000km and I was hoping to leave this until I have the transmission filter changed at 80000km). Any advice would be appreciated. Thanks. mexicov Last edited by mexicov; 05-05-2013 at 04:57 PM. Reason: spelling |
meh.
![]() Join Date: Jul 2010
Try posting this in the "F6, XR6T and G6ET" forums. You'll get more responses there in regards to aftermarket ZF coolers.
Thank you. I will work on a way of entering that thread.
mexicov |
