Old 05-05-2013, 03:17 PM   #1
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
Default AU Oil Leak - what is this thing that the oil is coming from?
G'day guys,
Recently my AU 6 cylinder has started to leak oil quite heavily, and today I jacked it up to see if I could find/rectify the problem. The sump is covered in oil, and I think I've found the source of the leak. It's this line shown below, located on the right hand side of the block, just above the oil filter. After starting the car up I noticed bubbles forming at the plastic connector. I was wondering if someone could tell me what it is, and how to fix it? Any help would be much appreciated. Here's the leaking line:
And a close up:
I have more photos of it if needs be..
Thanks!
THE SLUG - 1985 Toyota 4Runner
2.8L Turbo, 2.5" exhaust, 5" lift, 33" Mickey Thompson MTZs, lots of stickers
THE DAILY - 2006 BFII XR6T
Process West plenum, intercooler, intake kit, and throttle body relocation, 80lb injectors, 4" dump, twin 2.5" X-Force exhaust, high flow cat, ZF tune, 330rwkw @ 15 psi, 20" staggered MC Racing Simmons copies
THE TOY - 2000 AU Falcon
4.0L, 2.5" straight pipe, T5, BA brakes, spool, stripped out, slammed
THE SLUG is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2013, 03:19 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: AU Oil Leak - what is this thing that the oil is coming from?
Oil pressure sensor Nick
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2013, 03:26 PM   #3
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
Awesome, cheers.
Old 05-05-2013, 03:34 PM   #4
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
If anyone has a different opinion to Tony, please feel free to post what you think it is. A second opinion can't hurt! Having said that, Tony's most probably 100% right.
Old 05-05-2013, 04:01 PM   #5
MrEL
Sick Puppy
MrEL's Avatar
Oil pressure sender.
$30 fix and about half an hours work.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 02:48 PM   #6
TRAU BLAU
Yes,agree it's prob.the oil-pressure switch.I just did mine.Get 1"box spanner,take off the air-box,easy.The switch was made by Triden & cost $10 at Supercheap & taiwanese box spanner $6.It's poss.that the 10/40 oil I put in caused it to blow.After taking the switch out I put 5L of 10/30 in.
TRAU BLAU is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 09:03 PM   #7
millzy555
Oil sender unit??? Just make sure you get the correct size one, Fraud gave me a short one (plug doesnt fit/ light on dask comes on).
millzy555 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 09:14 PM   #8
foxtrot3
foxtrot3's Avatar
Hi. If it has a light on the dash it is an oil pressure switch and if it has a gauge it is a sender. Cheers MD
HI
I'M MICHAEL
foxtrot3 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 09:37 PM   #9
MrEL
Sick Puppy
MrEL's Avatar
Not on an AU.
Its the same sender for both guage and light models.
Old 09-05-2013, 09:49 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. Ok 1 trim level in 1 model out of 3700 car out there. Cheers MD
HI
I'M MICHAEL
Old 10-05-2013, 10:37 AM   #11
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Originally Posted by MrEL View Post
Not on an AU.
AU Xr's i6's do have a oil pressure sensor, my AU Futura has a sender / switch.
http://compare.ebay.com.au/like/3008...PriceItemTypes
http://compare.ebay.com.au/like/2512...PriceItemTypes
cheers, Maka
Old 11-05-2013, 11:11 AM   #12
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
Cheers for all the replies guys. I went to Autobahn the day I made this thread and got myself an oil pressure sender (the thing that screws into the block) to stick in. I haven't had a chance to fit it yet, but hopefully that should fix the problem. If not, I'll be back in here!
Old 11-05-2013, 12:50 PM   #13
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
i had a bad oil leak, check your timing chain tensioner underneath the powersteering pump. Mine had come loose and was ****ing out oil majorily.
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2013, 07:12 PM   #14
GK
Walking with God
GK's Avatar
If it's short, it's a switch. If it's long its a sender!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 12-05-2013, 07:15 PM   #15
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
GK
I always agree with GK
UK
Uncle_Ken is online now   Reply With Quote Multi-Quote with this Post
Old 12-05-2013, 09:41 PM   #16
MrEL
Sick Puppy
MrEL's Avatar
cheers, Maka
Seriously in the AU they are both the same switch.
All the guage is on an AU is a fancy light.
If you notice AU pressure gauges do not move when the car is idling or reving. The pressure never changes.
All AU's sit on the 5th bar of the guage!
The guage does nothing more then a light. They just have the electronics in the cluster set up to drive a guage so people believe it has a guage.
I went and bought a new sensor for the 5.0 in mine. Listed in the Triden book was AU Falcon , Fairmont and XR8 and the one part number. It is just a switch!
Old 12-05-2013, 09:44 PM   #17
KR1STO
Just another mock-up..
KR1STO's Avatar
AU1's did have a proper sender MrEL. I know the high series ones did.
In the series 2/3 yes they are just a switch..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2013, 09:48 PM   #18
MrEL
Sick Puppy
MrEL's Avatar
Thanks for clearing that up.
I didn't even think about the S1. Its amazing how e series they are still like.
The vehicle in question with the OP is a series 2 so my information was correct in this instance.
Old 12-05-2013, 11:52 PM   #19
FAT245
Lacking Imagination
FAT245's Avatar
My S1.5 Fairlane Moves ...
Old 14-05-2013, 07:40 PM   #20
GK
Walking with God
GK's Avatar
UK
Just need my wife to read this post! LOL!
GK
Now gone!
On LPG
Old 17-05-2013, 10:46 PM   #21
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
Actually you were incorrect, my AU is a series 1
Old 18-05-2013, 02:03 AM   #22
flooded one
I had that same problem with my AU ute its only a base model XL and is a series 2. cheap fix. pretty sure there all the same on all 3 series of AU
flooded one is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2013, 03:26 PM   #23
TRAU BLAU
Smile Re: AU Oil Leak - what is this thing that the oil is coming from?
G'day SLUG, along with the 1"box sock.you'll need an extension bar & then a swivel.
Old 18-05-2013, 05:03 PM   #24
jpblue1000
jpblue1000's Avatar
Originally Posted by wildrider View Post
...pretty sure there all the same on all 3 series of AU
Yep took one of my series 3 and put it on the series 1
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2013, 12:10 PM   #25
THE SLUG
REAL 4X4'S RATTLE
THE SLUG's Avatar
Thanks for the input everybody, the part I got from Autobahn was a sender unit. I still haven't actually got around to fixing it yet, but when I do hopefully it's the sender that's dead and not the switch!
Old 06-03-2014, 11:29 AM   #26
Beagle
How do mI stop the leak of the chain tensioner?
Beagle is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 06:31 PM   #27
Whoosha
AU DIE HARD
Whoosha's Avatar
Have a look here prety well covers it
http://www.fordforums.com.au/showthr...1238536&page=7
Originally Posted by Riksta
