Old 08-10-2012, 11:47 PM   #1
reds89
reds89's Avatar
Default 427 man o war
Can anybody tell me the specs[lift/duration etc]of a solid roller cam used in the 427/525hp world windsor man o war engine.
Need the specs to order a torque convertor to suit and not real keen on ripping a new engine apart to find out.
reds89 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 08:53 AM   #2
greencapri408
greencapri408's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Simon is a worthy recipient, his willingness to share  knowledge here for Forum Members and his wealth of knowledge. He has made himself available not only through the Forums but allowing members to contact him by mobile as required
Default Re: 427 man o war
Did it come with the dyno sheet?
If so that is all you will need to get a converter built
greencapri408 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 08:49 PM   #3
reds89
reds89's Avatar
Yep,come with a dyno sheet,gives a run down of hp and tq,fuel used etc,but nothing about the cam and can,t even find mention of valve lash,although i could get a set of feelers and check.
Would be nice to now what bumpstick it is though.
