29-02-2012, 09:50 PM | #1 | ||
so not sure if you have read my previous threads about the issue i am having with my car.
Symptoms: The first time this happened, when i started the car up it sounded like the belt slipping. Being only 2 months after buying, and being aa previously neglected car, i thought it was logical. Drove to work, which is 20kms one way, with the car squarking its head off. As i left work that arvo, it struggled to move. Pulled over, turned it off, fired her up with still a horrible noise and struggling to move. Limped it to the nearest garage where a few things were done as maintenance inc. alternator, water pump, pulleys, serp belt adn cooling sustem. When i picked it up it was a little better and the mechanic speculated the balancer. So more recently, often while driving, it will make the horrible noise followed by a drop in engine power for a moment. It may happen one after the other, sometimes randomly, sometimes from start up and somtimes while idle-ing. I have noticed that if i pull over and put it in nutural for a sec it can be ok. Feels like it is struggling to get fuel in the mornings also. Video of sound at idle. Cars in agarage atm getting new headers n cats, swaybars, plugs, coil pack n leads, balancer, oil, oil filter, fuel filter and shortly CAI (and probably ACRON box). Diagnosis? Some on here have suggested cam synchronizer? My first V8, so not that cluey, but it feels like something is struggling to rotate so cam synchro? crank sensor? Thoughts????
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
29-02-2012, 10:53 PM | #2 | ||
Sick Puppy
That sound slike your starter motor is trying to engage while the car is running still.
29-02-2012, 11:16 PM | #3 | |||
01-03-2012, 01:16 AM | #4 | ||
sounds nasty, it did`nt look like the belt jumped or anything when the cocky screeched , but who knows , maybe try the big screw driver stetherscope trick on the tappet cover, water pump housing, power steer housing,timing cover,air con pump housing on the actual starter while it`s on ramps etc very very carefully, it`s hard to wear a hat with a big screw driver through the nogon .
01-03-2012, 02:03 AM | #5 | ||
Tickford 220kw Windsor...
The squeal noise sounds like a shot or dry bearing in one of your idlers or the power steer pump or air con compressor. Maybe the a/c clutch is shagged.
You said he replaced the alternator and water pump. What other pully bearings/assys did he also replace? Id say its one of them he didnt. A replacement power steer pulley is the p/s box out and apart, possibly totally reco and the a/c pulley would need the compressor removed and system de-gassed etc..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue.... 2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver... __________________ AU Tickford Facebook fan page.. https://www.facebook.com/#!/home.php...25060040851023
01-03-2012, 10:20 AM | #6 | |||
Does the AC need to be turned on for the cluth to be engaged? never fooled around with these before. While the car is in the garage, ill ask the mechanic to keep looking around.
01-03-2012, 02:01 PM | #7 | ||
The main reason I mentioned the p/s and a/c bearings is because their not just a simple R & R replacement while its all in situ. Changeover p/s and a/c would have seen the cost of those repairs up there to the point that usually leaves you felt like you were royally bent over..
All the idlers, alternator and water pump are simple change over items that you can just replace with off the shelf parts, the a/c especially requires more work. P/s pumps can be bought of a p/s place off the shelf, but they would be like 250 plus just for a changeover unit, no fitting.
01-03-2012, 05:03 PM | #8 | ||
I second the starter motor. Our old EF did in a return spring and it sounding like that.
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
01-03-2012, 05:09 PM | #9 | ||
ok. thanks for the advice guys. I'll have to have a look at some point.
