24-02-2012, 11:00 PM | #1 | ||
AUII XR8
Hello All,
I have just reconnected my battery to the AU after about 1 month of being off the car (as I have not driven it much), and there is no signs of life, the battery was put on a trickle charger and it is a maintenance free battery so it has the little green panel to say it's all good for charge. Problem is when you connect the battery up there is no odo reading on the dash at all, and when you turn the key there is absolutely nothing, I can turn my lights on and have low/high beam. I have checked the battery terminals, wiring connections to the ECU and plugs are connected to the steering column area are all plugged in and not loose, what do you think is going on here? Thanks Brett
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw. |
24-02-2012, 11:07 PM | #2 | ||
Check all your fuses etc plug them in and out a few times. You may need get a test lamp on the job and check for battery at the key etc.
24-02-2012, 11:12 PM | #3 | ||
not here much anymore
does it say anything on the dash when you reconnect it. mine says 't' when it powers up, i then turn key back off then start it all the way and all is well.
RAM 1500
24-02-2012, 11:22 PM | #4 | ||
AUII XR8
Nothing is coming up on the dash at all, it usually does the "T" thing on the odo as well, but nothing is coming up.
I haven't checked the fuses yet, but would it be a relay? How often do they flog out?
24-02-2012, 11:28 PM | #5 | ||
Powered by Ford
Battery still can be faulty .. the green indicator runs only off one cell not all of them. I'm a battery rep and seen this a few times.
25-02-2012, 12:43 PM | #6 | ||
AUII XR8
I have had the battery load tested this morning and the battery is fine, so it has to be something else, it has me stumped as to what is could be, has anyone else experienced these issues before as well?
25-02-2012, 12:52 PM | #7 | ||
Sounds like the battery is dead, if you have a multimeter see how many volts its putting out.
should be around 12~ if its anything below its probably stuffed.
2001 Falcon Fairmont AU2 Big turbo coming Lsd |
25-02-2012, 03:07 PM | #8 | ||
Tickford 220kw Windsor...
I wonder if you may have tripped one of the breakers when you reconnected it?
If the batt did fine on a load test, then it more n likely isnt the issue..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue.... 2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver... __________________ AU Tickford Facebook fan page.. https://www.facebook.com/#!/home.php...25060040851023
25-02-2012, 05:44 PM | #9 | ||
Check for power at the key and get or print out a main power cct diagram and start chasing from the battery through the cct. You'll find it quick with a cct diagram.
25-02-2012, 07:40 PM | #10 | ||
did you miss any power wires as there are a couple that go to the bolt, also a fuseable link (fuse wire) these were a pretty common problem on the "E" series
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
