Old 13-02-2012, 07:37 PM   #1
FOCUSonTHIS
FOCUSonTHIS's Avatar
Default Grinding noise
As the title suggests I have a grinding noise coming from the left hand rear that only occurs now and then when I turn left, but not when I turn right. It sounds really bad and quiet embarrassing at times.
Has anyone had this issue before and could steer me in the right direction to fault find this problem.
Any information would be great thanks.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 13-02-2012, 08:23 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default Re: Grinding noise
IRS or Live Axle?
Wheel bearing perhaps. Also check your rear brake pads. If they are down to bugger all then the calliper will be very close to the disc and it wouldn't take much lateral movement for the disc to grind on the calliper if the bearing has a little play in it.
Bushbasher
MINE- AUII Forte
Old 13-02-2012, 08:32 PM   #3
chrisvess
Also check ballpoint hasn't collapsed into rotor
chrisvess is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 09:18 PM   #4
FOCUSonTHIS
It is live axle. I was thinking wheel bearing also.
Anymore ideas?
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 13-02-2012, 09:57 PM   #5
chrisvess
Lol just retread it's rear
Old 13-02-2012, 10:45 PM   #6
FOCUSonTHIS
Why would I need new tyres? LOL
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 13-02-2012, 11:02 PM   #7
GK
Walking with God
GK's Avatar
Could be the handbrake shoes rubbing. Might need to back the handbrake off a tad.
Sounds silly I know, but I've heard mine rubbing on one side when going round corners.
Left rear in the wagon it was.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-02-2012, 11:05 PM   #8
FOCUSonTHIS
GK
Was told my handbrake isn't the best either. So I think I need to do a process of elimination
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 13-02-2012, 11:22 PM   #9
chrisvess
Auto correct going spastic I meant re read the original post
Old 21-02-2012, 09:32 PM   #10
FOCUSonTHIS
Finally got to root cause this issue. It is the LHR hand brake shoe rubbing on the disc. So I will repair that. Also took my axles out to replace the bearings while I was at it. Found out that they were not packed with grease when replaced previously and some genius used silicon on it as well.
Also low diff oil, as when they took the axle out they didn't replace the loss of fluid. Lucky my diff isn't whining.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
