Old 28-01-2012, 05:58 PM   #1
vipa
Default cortina 4 speed problem
Hi i have just bought a 1980 2l 4speed cortina and there is a lot of play in the gearstick,the gearbox drives ok but the gear stick wobbles all of the joint can any one help is it a bush or is the box stuffed.
Cheers Darren
vipa is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 03:02 PM   #2
vipa
Default Re: cortina 4 speed problem
Cheers Darren
some one should know some thing......so many post up and no one with any info ....lol
Old 29-01-2012, 09:37 PM   #3
wombat2509
wombat2509's Avatar
Hello vipa
To be honest I know nothing about Cortinas, but you could try either
Smaka
classicescortparts.com.au/index.php/online-shop
or The Capri Clinic
www.capriclinic.com
both have parts for 4 speed gearbox gearsticks.
I have dealt with both places and can't speak highly enough about either, if it is not listed just ring great people to deal with .
Hope this helps
Wombat
wombat2509 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2012, 09:50 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
Have you checked the top of the box ware the shifter mounts ? I am guessing it a single rail type box with the screw in nylon bush which did tend to undo or split
Originally Posted by Riksta
Old 30-01-2012, 01:45 PM   #5
SBRacing80
yeap if its the single rail with the nylon screw in bush id be 99% sure its deteriorated, youd probably be able to just pull the shifter right out of where its mount atm...
SBRacing80 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2012, 09:17 PM   #6
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
hi mate
try capri clinic.. kevin knows his stuff well. he will put you in the right place .. and for not much eather ..
lets us know how you go
cheers
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2012, 02:12 PM   #7
Pazuzu
Had the same problem with my Escort several months back. I'm almost sure it's the gear shifter rail mount bush. Piece of P!ss to fix it up. I took out the console, removed the gear knob, off with the dust boots, expose the castellated flange, unscrew it, & you're there. You'll see a rail where the fork of your gear shifter sits. If there's no bush there & it's just a metal rail, then the bush has disintegrated. I just jumped on ebay, bought my new bush from the seller "Parts_Lunacy" for $20. The nylon ball on my gear shifter had carked it as well, grabbed a whole new shifter from the seller "Performancelamps" for $40. Make sure you check the distance between the thick ends of the gear rail, and check the lengths specificed on parts lunacy's shop. I had to file the bush I bought down a few mm. Before you mount the new bush, fish out all of the crud from the old bush that'll be floating around in there- at least get rid of the chunkiest bits. Clip your new saddle on, mount the shifter fork on the new bush, screw the retaining nut in, whack on your dust boots & you're all sorted.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
