When I lock the drivers door on the AU wagon it actuates all the locks. However when the drivers side doors are locked and I lift the front passengers side external handle the door opens and I hear both passenger door locks cycle. Is it a dodgey actuator in the front passengers door?
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
What series AU and and do all the doors really lock? I would lock with the remote try the drivers side then try the others. What happens?
Uk
#3 | |||
I ♥ EDM
![]() Join Date: Aug 2006
Your passenger front door actuator needs replacing. Without a doubt.
I agree with Scotty85. Use trial and error to see which one has gone.
UK
Its a common issue the plastic gear inside breaks BA/BF and AU actuators are the same part number
I replaced the front passenger door actuator with a BA one from the wreckers. Problem solved. Thanks fellas.
That'll be 1 beer thanks
![]() UK
#9 | |||
The wagon changed hands yesterday so no more door lock troubles for me. I just read your write up on replacing the internal mirror on an AU. That is my next job on my XR6, so it will probably 2 beers I owe you. Regards Jono. |
#10 | |||
I ♥ EDM
#11 | |||
![]() UK
