Old 24-11-2011, 12:06 PM   #1
borry
Now With 2 Cylinders More
Default AU Starting Dramas
Gday guys,
about a week ago, I jumped in the ute as usual (AUII XLS 302) it started, then died. Started, then died. Then would not start at all. I disconnected the battery, left it for 5, reconnected it, waiting 20 mins and presto, started no dramas.
Its doing it to me again this morning..
Now it "seems" to be a problem with the immobiliser ? as once it starts it will run perfectly fine. The starter solenoid isnt trying to click over, the battery has plenty of grunt (itll turn over no dramas otherwise) and I cant seem to find any other faults.
So. If this is the case, what is the answer ?
The only other problem I can think of, is that when i bought the ute (+/-6 months ago) there was a problem with the ignition barrel. I got that replaced, and it came along with a new (non ford) generic key. So I can only assume the new key has a new battery in it also ?
Bit stumped... and grumpy, as I was about to go out... and now I cant
borry is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2011, 08:07 PM   #2
borry
Default Re: AU Starting Dramas
seems i have it down to being a faulty BCM. any info on changing one ? getting one ? getting on scanned to suit the existing ECU etc ?
Old 24-11-2011, 08:26 PM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
This should answer all questions:
http://www.fordforums.com.au/vbporta...article&id=765
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
