Old 16-11-2011, 06:28 PM   #1
rowan194
Default Replacing idler pulley AUIII 6 cyl non-VCT
I noticed one of my pulleys was a bit clattery when I changed my belt a couple of months ago, and came across this today...
http://www.ebay.com.au/itm/GENUINE-F...item3a6b692380
(A kit of two genuine ford pulleys)
So how do you replace these pulleys, do you need a special tool or press to remove them? I saw mention in another thread about undoing 4 bolts, but I can't see anything like that on the ebay pics. Are they missing something?
Alternatively, could I just replace the entire tensioner assembly?
I have to go to Bayford to pick up a heater pipe o-ring so I figured I may as well do this at the same time.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2011, 06:33 PM   #2
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Default Re: Replacing idler pulley AUIII 6 cyl non-VCT
There is a bolt on the back, 1/2" from memory .
HTH.
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2011, 11:13 PM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Remove the tensioner assembly, then each wheel is held on by a single bolt. Did the pulleys come with the bearings in them? Those bearings are the part that goes and can be carefully pressed out with a hammer and socket , but usually you can buy pulleys with the bearings already fitted.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2011, 11:33 PM   #4
Beer Baron
I bought nuline pulleys that are metal with bearings that can be pressed out.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2011, 04:02 PM   #5
rowan194
I went to Bayford spares (Campbellfield) today and they did the $42 deal for me. I think it's usually about $5 more if you just buy the two idlers separately.
I can hold the middle and spin the wheel freely so I guess it includes the bearings.
