08-11-2011, 10:36 AM | #1 | ||
A few screw loose
Although I'm not really a mad tuner/modder with my rides, a little aftermarket goodies to bolt-on (e.g. air filter, CAI, exhaust, ECU) doesn't really hurt, I guess? Just starting up a thread to cater for LW owners (or future owners) whom would like to spruce up their Focus a little.
K&N Replacement Air Filter (Part E-2993): Product Style: Round Air Filter Height: 8.25 in (210 mm) Inner Wire: No Inside Diameter: 2.75 in (70 mm) Outside Diameter: 6.25 in (159 mm) Top Style: Plastic Top Material/Finish: None Filter Material: Cotton Gauze Filter Re-Oiling Amount: 1.76 oz (52ml) Weight: 1.4 lb (0.6 kg) Product Box Length: 6.31 in (160 mm) Product Box Width: 6.31 in (160 mm) Product Box Height: 10.19 in (259 mm) Source: http://www.knfilters.com/search/prod...px?Prod=E-2993 Note: It seems to be also the same filter cartridge used in the LV Focus. Looks like I'm gonna get this baby off eBay soon |
08-11-2011, 01:16 PM | #2 | ||
A few screw loose
2012 Ford Focus Hatch Cat-Back Muffler from Ford Racing Performance Fits 2012 Ford Focus Hatchback manual and automatic transmission with PZEV Evaporative Emission T-304 stainless steel construction with polished tips Performance tuned cat-back exhaust system Includes exhaust clamps for weld-free install Package Dimensions: 13.00 x 15.50 x 61.0 Package Weight: 33.4 lbs Source: http://www.fordracingparts.com/parts...KeyField=12976 Only for the Hatch, bleh |
13-11-2011, 10:08 AM | #3 | ||
Barra Turbo > V8
ECU tuning will more then likely lose you your warranty.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
13-11-2011, 04:48 PM | #4 | |||
A few screw loose
13-11-2011, 08:29 PM | #5 | ||
Buell Man
Not worth the risk for me.
LW Ford Focus Titanium SY MKII - TS RWD Buell XB12Ss Harley Fat Bob |
15-11-2011, 09:38 PM | #6 | ||
Hit Austraila at the end of November via http://www.rocketindustries.com.au/ I have had it on order for 2 mths now
LW Focus Sports Turbo Diesel Hatch |
15-11-2011, 09:41 PM | #7 | |||
Barra Turbo > V8
15-11-2011, 10:06 PM | #8 | |||
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
15-11-2011, 10:34 PM | #9 | |||
A few screw loose
16-11-2011, 12:37 PM | #10 | |||
16-11-2011, 05:12 PM | #11 | ||
$675 USD ..... $1020 AUD supplied from Race Parts Australia (FRP Supplier) in Queensland ... think I'll check out some other options.
16-11-2011, 10:56 PM | #12 | ||
A few screw loose
Whiteline Sway Bar (Front) Diameter: 22mm Material: Solid Spring Steel Adjustment: Non-adjustable Weight: 7kg Length: 120cm Width: 22cm Height: 15cm Source: http://www.whiteline.com.au/product_...t_number=BMF51 Whiteline Sway Bar (Rear) Diameter: 22mm Material: Solid Spring Steel Adjustment: 2 point adjustable Weight: 4kg Length: 70cm Width: 22cm Height: 15cm Source: http://www.whiteline.com.au/product_..._number=BMR78Z |
17-11-2011, 12:24 PM | #13 | ||
Can you post up some pics of the mods. I think mine would look great with that exhaust.
2012 XR6 Limited Edition in Kinetic |
17-11-2011, 09:00 PM | #14 | ||
Sway bars will be my first mod I was only wondering the other day whether or not Whiteline had released sawy bars for our cars yet. W00t!
17-11-2011, 10:38 PM | #15 | |||
A few screw loose
17-11-2011, 10:52 PM | #16 | ||
A few screw loose
Weapon R - Secret Weapon Air Intake System The Secret Weapon Intake was designed, to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other. This technology increases air volume and speed to the engine, which naturally feeds the engine 3x more air than the conventional air intake system. The intake pipe is bent out of high quality 6061 Aluminum on our Automated CNC mandrel bender. Polished to a high show quality finish. The SW1 Air filter features a tuned velocity stack to increase velocity and decrease turbulence. Only Comes In Polished. 1 Million Mile Limited Warranty Open pore high density re-usable foam Source: http://www.carid.com/2012-ford-focus...ke-285269.html |
17-11-2011, 11:44 PM | #17 | ||
It's great to see the aftermarket goodies coming through. Not entirely convinced about the CAI. I'd like to see a pic of it installed before I'd even consider it. I would hope that theres some sort of shielding from the engine bay.
In some cases putting on a CAI could see you going backwards as far as power is concerned. I'm in the process of getting my wife's forester tuned and theyve changed the design of the air box a fair bit, and tuners have found that what would previously be a gain in power with a CAI, is now a waste of $500 or so. |
21-11-2011, 04:02 PM | #18 | ||
A few screw loose
Hmm.. any other suggestions on other type of mods you guys would like to see on the Focus? Haven't really seen any bodykit parts out there on the open market
01-12-2011, 12:22 AM | #19 | ||
A few screw loose
.. okay, I'm probably gonna ask a dumb question. How do you remove the stock air-box cover to change the air filter element? I can't seem to get it open. I did see 3 hexagon-shaped plastic looking nut/screw but since I don't have a ratchet, couldnt test if that will loosen. Any ideas? Haven't owned a Ford prior to this so not familiar with this configuration. Thanks!
01-12-2011, 01:05 AM | #20 | ||
If it's like the LV, and from what I can see it is, loosen the hexagon-headed screws in the top of the airbox lid and simply lift the lid off. The top of the filter is actually the right-hand side of the airbox.
Here's some progress shots of a K&N install.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. Last edited by In Focus; 01-12-2011 at 01:11 AM. |
01-12-2011, 08:31 AM | #21 | ||
Yeppers! Damn near identical with the LW
01-12-2011, 08:32 AM | #22 | ||
ps Dropping by hitech mufflers this weekend. Will definitely put up some photo's if I get psyched enough to get some work done.
01-12-2011, 08:43 AM | #23 | ||
A few screw loose
Thanks a bunch, In Focus. The photos are mighty helpful. Now I can head along and get my K&N air filter in there.
03-12-2011, 08:31 PM | #24 | ||
A few screw loose
.. just ordered this over eBay. Cost about $65 (inclusive of shipping and handling). Can't wait to install this baby in! |
04-12-2011, 09:45 AM | #25 | ||
Sysh Don't suppose you can supply me with a link? That's a pretty awesome price. Can't seem to find the seller that you've bought it from though.
04-12-2011, 04:31 PM | #26 | ||
http://www.ebay.com.au/itm/FORD-Focu...ht_7874wt_1185
The cheapest I could find from a quick search on e-bay.
04-12-2011, 06:46 PM | #27 | ||
A few screw loose
I'll PM you after this, currently out at the moment
04-12-2011, 07:43 PM | #28 | |||
A few screw loose
15-12-2011, 10:51 AM | #29 | ||
Are your speakers crap?
I think that mine are shot after 2 months. Need to get a sub and change speakers I think
15-12-2011, 11:56 AM | #30 | ||
A few screw loose
.. mine are still okay after 1 1/2 months. Have you been blasting them out loud? Can't ya just bring it back to the dealer and claim warranty?
