Old 06-11-2011, 05:23 PM   #1
cram72
Default Rear Sway Bar
Got a stock 1.6 two door coupe and have an rs2000 sway bar. Only difference I can see is that the exhaust mounting centre box that the bush would bolt through on an rs appears welded?
Has anyone ever fitted one? Do you just cut off the old mount and then weld a bolt on?
Ideas appreciated.
cram72 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2011, 10:33 PM   #2
Jimmyd
Default Re: Rear Sway Bar
Can you post a pic of the mount?
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2011, 06:21 AM   #3
whooligan
whooligan's Avatar
The RS (2lts) have an extended exhaust mount which comes off the swaybar chassis mount. Is basically a threaded tube that tapers to pick up the rubber exhaust hanger.
whooligan is offline   Reply With Quote Multi-Quote with this Post
