Old 01-11-2011, 11:08 PM   #1
stoodoo
Falcon R.I.P. 1960 - 2016
stoodoo's Avatar
Default Info on gasket leak
Hey guys, I have a small but annoying oil leak, between the timing chain cover and cylinder head/cylinder block area. I pulled off the power steering pump brackets hoping that it would just be a leaking tensioner, but it wasn't. I have read two contradicting pieces of info, the first being that if you take the timing cover off, you need to take off the cylinder head and drop the sump to replace all the seals. The second bit of info I read (and was told by Ford service dept) was that you do not need to drop the sump or remove the cylinder head to replace the gaskets. Has anyone removed their timing covers and replaced gaskets, without dropping their sumps and removing cylinder heads? Advice appreciated.
stoodoo is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 02:19 AM   #2
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Default Re: Info on gasket leak
Standard Falcon mate
You need to pull the radiator to make room to pull the harmonic balancer.
Then you need to pull the chain tensioner.
Then you need to drop the sump about 1/4 inch at the front to release the pressure.
Then you can take the timing cover off.
Rockerbox is optional if you want to see a bit better, head definitely does not need to come off!!!!!
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2011, 11:00 AM   #3
stoodoo
stoodoo's Avatar
Thanks for the reply, I've bought a specific au/ba falcon harmonic balancer puller for this job, so I hopefully won't need to remove the radiator.
Old 02-11-2011, 11:30 AM   #4
FGII-XR6
FGII-XR6's Avatar
there is a cheat that often works you will need to remove all the bolt ons from the front of the engine then grind a hacksaw blade into a hooked end and scrape out the old gasket clean with metho till all oil is gone then squirt black or blue silicone ( the good high temp gasket one ) into the gap. leave at least 12 hours before starting the engine. this works most of the time providing you do a good job of cleaning up
[SIGPIC][/SIGPIC]
Rides:
Old 23-02-2012, 12:57 AM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Sorry to bring up an old thread, but I need to sort out an oil leak from the timing cover to the head.
Looking around for a ford specific puller, which hopefully a good tool shop will have.
My question is, does an specific installation tool need to be used to get the balancer back on? or did you just torque the bolt back on?
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2012, 07:39 PM   #6
mik
mik's Avatar
i already had a general purpose harmonic remover , and it did`nt do the job(get the harmonic off), it needs the claw type legs that face inwards towards the bolt, i ended up fabricating some new legs for the puller,
you should be able to pull it back on with the bolt, just make sure it`s on the keyway..
Old 23-02-2012, 10:47 PM   #7
Evgeni
Auto Nerd
Evgeni's Avatar
Thanks for your reply. I found a shop in the local area selling ford spec pullers for $190. I figured I have damaged enough things in the past by using the wrong tool - knowing my luck I'll end up pulling the thing out of shape with the wrong puller.
I'll try wind the bolt back in by hand first on reassembly. Bit nervous about snapping the bolt with the impact.
Anyway will let you know how I go.
Old 24-02-2012, 01:54 AM   #8
mongrelEF
Bugger!
mongrelEF's Avatar
Just a bit of reassurance for you - my preferred method is to tap the balancer back on lightly with a lump hammer, screw the bolt in by hand, and then hit it with a rattle gun. Works every time!
Old 22-03-2012, 10:46 PM   #9
Evgeni
Auto Nerd
Evgeni's Avatar
Just an update. Didn't end up doing the timing cover. I just sealed up the corners where the cover meets the head.
The leak was mainly coming from the sump and dip stick tube. So spent two days replacing the sump gasket, dip stick o ring - did the intake manifold gasket and water pump whilst I was at it.
A blessing in disguise was my neighbour who came out to complain about the noise the air compressor was making. It forced me to put all the front suspension back with a torque wrench. After I reset the alignment, the thing is as straight as an arrow. Feels like a new car. With the same alignment setting previously, it used to pull ever so slightly to the left, so it must of been different tensions in the various components.
Old 23-03-2012, 06:55 PM   #10
mik
mik's Avatar
good stuff mate, so has that eliminated your oil leaks completly?
Old 23-03-2012, 10:53 PM   #11
Evgeni
Auto Nerd
Evgeni's Avatar
Touch wood, but yes, I am temporarily a lucky owner of an AU that does not leak - air, water or oil. About two years ago, I did the rocker gasket and the rear main, so I am hoping it will be trouble free for another 100,000k.
I will post up some pics once I cut them down to size.
Old 24-03-2012, 01:42 AM   #12
Evgeni
Auto Nerd
Evgeni's Avatar
Here are some photos. The leak from the dip stick tube was blowing all over the block. You can see it once the intake manifold was removed.
For 200000k and only changing the oil every 15000km, it didn't look that bad at all. Fairly impressed - was using Castrol 15-40w, but with this job I just bouight some cheaper oil - Gulf Western 10-30w. Was going to flush it out, but thought just to leave it for another 15000km.....if it aint broke....
Old 24-03-2012, 01:48 AM   #13
Evgeni
Auto Nerd
Evgeni's Avatar
The most time consuming task was cleaning up the surfaces.
Old 24-03-2012, 03:28 PM   #14
mik
mik's Avatar
good job mate, good pics too.
