xt 500 P plater
whats the difference between a normal inline 6 out of an AU forte or a VCT 6 out of an xr or fairlane ?
cheers
low n loud |
VCT, Variable cam timing.
In the VCT engine the cam timing can be advanced or retarded to allow for changes in gas flow at various rev ranges. The AU had one cam for both inlet and exhaust, BA had 2 (1 for in 1 for ex)which were syncronised and then BF and later have 2 that are independent from each other. Intec has fixed timing on 1 cam only |
Peter Car
Cylinder head and rocker cover were quite different at the front. But it also had the tweaks the non VCT XR6 engine got like bigger valves etc and a bigger exhaust.
From memory everything below the head was the same. |
Intech 157kw/357nm
XR6 HO 164kw/366nm VCT Fairmont/lane 168kw/370nm VCT XR6 172kw/374nm |
#5 | |||
Barra Turbo > V8
XR6 HP 164kw/366nm VCT Fairmont/lane 168kw/370nm VCT XR6 172kw/374nm Not being picky ![]()
-2011 XR6 Turbo Ute -2022 Hyundai Tucson Highlander Diesel N Line |
