06-07-2011, 12:47 AM | #1 | ||
Anyone know if they are out there for AUs? And didmt how much they cost? Also, while dling the rebuild, what else should I look at doing?
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
06-07-2011, 09:31 AM | #2 | ||
I think ACL do a re ring kit for the AU but not a full rebuild kit with pistons
[SIGPIC][/SIGPIC]
06-07-2011, 01:01 PM | #3 | ||
just checked ACL don't do the kit for the AU here are the various part numbers you will need
Full Gasket Set GR525MT Piston Ring Set C1903Mahle or C9128 C9128 is a high performance ring set suit the 9414S piston.ACL Race Series Main Bearing Set 7M2092 O/S: STD, 001, 010, 020, 030, 040ACL Duraglide7M2092H O/S: STD, 001, 010, 020ACL Race Series 7M2092HXO/S: STDACL Race Series Conrod Bearing Set 6B2150 O/S: STD, 001, 010, 020, 030, 040ACL Duraglide 6B2150H O/S: STD, 001, 010, 020ACL Race Series 6B2150HX 0.001" extra oil clearance on STD journal. O/S: STDACL Race Series Piston Assembly Set 6MKRY4002Mahle 6MKRY9414S a high compression piston kit which can be used for LPG conversions or performance applications with the following indicative compression ratio: 10.2:1 @ 73.4cc total clearance volume. ACL Race Series 6MKRY9414S would be a good option if you were prepared to use 98RON fuel and / or LPG for a full listing go here http://catalog.acl.com.au/aclwebcata...ttype=0&pg=all of course machining would be needed too. good luck
[SIGPIC][/SIGPIC]
06-07-2011, 01:33 PM | #4 | ||
Cheers mate
06-07-2011, 10:01 PM | #5 | ||
Gem engines do exchange rebuilt motors but stockers only i think.
AU XLS. |
