hey guys i wanna put an au 6 into an tc-td or te-tf will start with 6 cylinder body.
basically how hard is this also car will be straight gas as i wanna go turbo down the track auto will be a c6 also what is the best diff to go and how much tyre on a 15 inch rim will fit front and back |
on the tyre issue depending on wat offset u run u wont be able to get much more than a 225 on there without some sort of tubbing
ok thanks for that
Forgot to mention before that the cortina diff is failry solid however a nine in ch will obviously be ur best bet if its gonna be putting out some decent power. im not sure about the TC/D/F. but if u go with a TE and decided to retain the original diff ur gonna need to reinforce the area where the upper trailing arms bolt onto the chassis, these r a weak spot and have a habit of tearing off. I had a 2L in my first corty and managed to rip it off with some spirited driving, so it wont be hard for u to do it with a turbo 6.
excellent thats good to know
dont go nine inch ridiculous over kill really isnt necessary massivly over priced and robs alot of power plus the extra weight. go with a 28 spline centre from an e series or a vl turbo i think have to check that out. also hardest part for au 6 is the alloy sump very difficult to modify theres more stuff cant think of it right now though.
Corty diff is a weak pos with any power through it lol. go 28 spline e series centre and a set of billet axles. Best move mate. 9'' is overkill imho.
