Hey people
I was wondering if anyone can tell me what diffs are compatible with an AU ute. will wagon diffs fit? are there different handbrake setups out there? different tailshafts setups? cheers frank |
![]() Join Date: Aug 2005
BA Utes and Wagons up to 10/2005 use the same housing so I can't see why you couldn't use a BA Wagon or Ute diff or an AU wagon diff assy.
#3 | |||
RIP...
It's only slight though and extremely easy to overcome.
. Oval Everywhere... |
I can tell you that I put an LSD from a ute into my wagon originally and everything bolted straight in. If there was a difference I couldn't see it. This was an AU diff into an AU wagon though. Apart from the handbrake set up on newer models everything else will still bolt up without any problems.
Rhys
Toy Car Build |
#5 | |||
RIP...
The difference is where the handbrake brackets are mounted.
cheers for the help! this should turn out cheaper than a diff rebuild
