quick question. im thinking of getting my brake calipers powdercoated as i have tried to paint them the colour that i want but it just doesnt come out how i wanted. anyone know a rough ball park of what it might cost?
Now Ford-less ![]() But good things are coming in 6 months
Minimum charge is usually $60 or there abouts mate.. So i wait till i need a few things done at once..
My wheels cost $300 everytime i get them done a hell of a lot cheaper than buying new wheels everytime.. $75 a wheel is pretty good value IMO... |
sweet, how would i go with things like brake calipers? would i have to pull them all apart and seal parts up or would they do it?
A powder coating place should be able to answer that question
Youd have to pull them apart yourself.
As for sealing most places will want you to do that as most part just go into a pile and it can be forgotten which bits are not to powdercoated.
You've seen it, you've heard it and your still asking questions?? Don't write off the Goose until you see the box going into the hole.... |
#6 | |||
![]() I havn't powdercoated mine yet mate because you will need to tape up wherever you dont want the sand or paint to get, this is a critical part of your vehicles safety so do some research on preparation first OK ... At a minimum where the piston sits plus the sliders will need to be scraped/tapped to remove the excess paint and clearances checked new seals fitted etc... Maybe call PBR direct and ask them whats involved in the process as they sell Powdercoated calipers in their upgrade packages... http://www.pbr.com.au/ Hope this helps... Daz. |
#7 | |||
Anytime mate .. shoot some pics up if ya go ahead with it ...
I know powdercoating is better, but i am a complete novice and gave it a crack with spraypaint and came up sweet. I didn't even do jack all prep, they looked messy as hell. Gave them a quick wipe and just started spraying. didnt like the first colour so went again with another, thinkin thats why they turned out good bcoz they all got about 7 coats
Build thread:
http://www.fordforums.com.au/showthr...ghlight=futura |
#10 | |||
![]() i was gonna get my wheels done last year but i thought stuff it i wait till i closer to taking the car out, it was about $80 then. now it's $150 damn u fashionable people ![]() |
#11 | |||
#12 | ||
Wouldn't recommend powder coating for the caliper (or anywhere that gets hot..), the heat effects the quality of the powder, and worst case may even "melt" it off. Powder coatings cure at only 200 degrees, I'm sure brakes/calipers would generate enough radient heat to cause problems. I'd go for a high temp paint. Painted properly they look the part and last a while. Sandblast first, use the right primer and high temp paint. Hope this helps.
yeah ive tried but im trying to get a conary yellow but no where i find sells one that works and i have got the darkest yellow that i could find and stil not happy. but arnt brakes like brembos etc powder coated
#14 | |||
#15 | ||
Yeah thanks daz I checked itt out the other night. Called a local powder coating place they said it will cost me $15 per caliper not including sand blasting, they also put me in touch with another local group that do a lot of sand blasting of car parts. Called em and they have this really thick plastic tape and covers they use for brakes. Although since I have ****y stock brakes ganna get the prem pbr brakes or equivilent second hand an get them done. Means I won't have down time without the car
