With da Warlords
Hi All.
I have only just started using the A/C in the car over the last week. Anyway, I noticed a few days ago that the compresser seems to be cutting in and out constantly. ie. click on - 1 sec later - click off. The A/C still seems to work fine, other than the compresser cutting in and out constantly. I have noticed that at idle, the A/C doesnt appear to work as well as usual, but once driving (above 2000 odd rpm) it seems fine. Anybody have any ideas? I've checked the connection and it appears secure, but I have no bloody idea what else could be the problem. Cheers in advance ![]()
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
Giddy up.
Not low on gas ? .
With da Warlords
I have no idea, I've never re-gassed it in the 5 years i've owned it. So that is definately plausible.
Does the compressor cut in and out when low on gas?
Custom e-series owner
yeah they have a pressure switch in the system so if theres no gas/pressure in the lines it won't opperate to stop from stuffing the compressor completely
go get the system checked. it might have had dye put in it so if leaking is easy to find.
88 ea falcon fresh paint, 20 inch chrome wheels, ed xr front, scorcher body kit, ef/el mirrors and door trims, UPC 330mm twin piston big brakes, manual, front adjustable coil overs, 2.5 inch exhaust, twin thermos etc etc **atomic built 660kw AU engine being fitted**
Giddy up.
Yeah mine did when it was low on gas, that's all it was.
With da Warlords
Cheers fellas, my first port of call is to check the a/c at the local shop I suppose.
I'll check back with results later. Thanks
Giddy up.
No worries mate, it's normally this time of yr when you find problem's with the air cond as it's when it is needed, 40 deg today
Yep, same thing happened to me this time last year. Turned out the compressor was shagged... Similar symptoms to mine, but mine wasn't getting cold at all.
FPV GS Ute #370/Brembo brakes |
Hi James,
When you switch on your A/C do the fans come on regardless of engine temp? If you have a condennsor thats getting to hot it will casue the commpressor to cut in and out to combat the heat buildup (safty messure). Now you mention it works fine while driving at say 2000rpm around 100kmh or so. This would provide enough airflow to cool the condensor and keep it happy. My guess is that if it was low on gas it would cut out regardless of rpm or vehicle speed. I would be looking at the electrics that switch on the fans also. Worth a shot before you blow all your cash on a regass. Aslo, not sure if it works on AUs but on the E series if you unpluged the temp sender harness from the sender it used to make the fans come on flat stick, might be worth a try as that would cool the condensor and stop it from cutting out. Cheers Doug |
With da Warlords
Hi GasXD
The thermofans only switch onto high speed at around 92.0C. They go back to low speed once it drops back into the mid 80's Thermofans have always worked that way since I've had the vehicle, and I've never had a/c problems before now. When i mention 2000rpm, its not on a hwy. I can be sitting still, and at idle with the compresser cutting in and out the air is only sort of cold, but with a few more rpm (2000+) and still not moving the air will go cold. I think its just the extra rpm's making that compresser work more for the second its on before it clicks off again. Another reason I don't believe its the condensor is that I can start the car (stone cold) first thing in the morning and straight away the a/c is clicking on and off, and nothings even warm at that point. So that should rule out the condensor? Thanks for the input though, all idea's welcome lol
Could be electrical, maybe the pulley clutch. Unplug the clutch wire (the single wire near the pulley), and connect it to 12 volts directly. This bypasses the pressure switch and everything, if it still clicks off and on, then it is a faulty clutch. Don't let it run like that for very long (in case it is low on gas).
