Have a bit of a squeeking noise come from the front of my AU3,originally thought it be the struts because to me sounds like a shagged strut,but i put in some other struts and the noise is still there,any ideas where it could be coming from?.
Im thinking maybe sway bar rubbers or engine mount. But the strange thing is it gets alot worse and seems to appear when the air cons on. It sounds exactlty like rubber rubbing against something (not the tyres,its certainly a suspension problem).Ive had someone push up and down on the front of the car when its stationary but no noise. Any idea whould be great,it gets pretty annoying hearing it. |
meh.
![]() Join Date: Jul 2010
probably the thermos fans.... the ones in the EF at the moment do that and its nothing really....
#3 | |||
i came across a ZH fairlane that had a squeek in the engine bay somewhere it sounded like loose exhaust flanges , turned out the heater hoses where rubbing against each other when the engine moved/rocked, some cable ties all fixed, i was also thinking water pump and or belt tensioner pulley, possibly alternator? front brakes .wheel bearings?
Feel the boost
straight up mate, check your ball joints. I had the exact same problem just before christmas.
2005 BA Mk2 XR8 ...... Let the fun begin ![]() Drive carefully! Remember, it's not only a car that can be recalled by it's maker. |
#6 | |||
Feel the boost
just replaced them mate. They're a sealed unit. But not very expensive, i got them from repco.
