Hi,
I guess its a silly question - but for the life of me when I plug my Iphone 3gs into the USB socket with the iphone/usb cable, it synchronises OK, though it will only play music through the Aux -> Bluetooth function, and not the Aux -> Ipod function. Any ideas why? Thanks & Cheers Steve |
sucksqueezebangblow
check the iphone itself, sometimes the bluetooth logo lights up - transmitting through the bt. if you tap the logo, you should get the option to select the headphone jack.
previous:-> 74 KE20 4AGTE, 04 RZN149R, 01 AE112R, 01 KR42R, 84 E30 318i, 67 MINI DELUX, 06 BF XR6T, 08 V50 T5 AWD , MY13 ISUZU D-MAX 4X4 current:-> 16 SS Sportwagon, 19 Everest BiTurbo 4WD |
Thanks.
If I select ipod on the phone, then the input logo - ford audio and line in are available. When I select line in, no audio is present. The ford audio (which I believe is BT audio) plays the sound thru BT audio. I just had the expectation that if you plugged the phone in using the iphone cable, and it syncs up, it would play through the line in not BT audio. Cheers Steve |
Nokia actually makes the Bluetooth module, so you can see why it doesn't sync perfectly with the iPhone. Then again, I'd much rather press a few extra buttons and keep the iPhone!
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec |
you have to plut line-in to the headphone jack next to the USB socket, btw.
you cant just use regular ipod cable, it needs to go from ipod 30-pin connector to USB+3.5mm jack... |
You mad, bro?
Yep, that's correct. You'll need something that looks like this:
2009 LV Focus XR5 Turbo Performance Blue SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
thank you!!! :-)
