Old 23-10-2010, 09:53 PM   #1
Cav
HUGH JARSE
Cav's Avatar
Default Noisy gearbox
I have a 1981 TF GL Cortina 200 4 speed.
It only has about 80,000kms on it.
The gearbox whines in all gears except top gear (4th) which is quiet.
Do they all so this?
Or do you think I may have a bearing problem?
Cav is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2010, 12:23 PM   #2
caprispecial
Yes it should run quiet so there is a problem. If it is quiet in top gear then my guess is the layshaft/bearings and or the bearing that goes between the input shaft and the mainshaft.
caprispecial is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2010, 01:27 PM   #3
Cav
HUGH JARSE
Cav's Avatar
It get's driven about once a month. I'll get the gearbox overhauled, my guess is it will get noisier eh?
Old 27-10-2010, 11:42 AM   #4
Mainlube
Mainlube's Avatar
Overhauled is the correct way to go .... or .....
If you didn't have the time then you could buy a couple of years grace with flushing and applying the Mainlube Synthetic Solid Boundary E P Gear Oil
Just a thought
Steve
MainLube - Extreme Lubricants For Overdriven Machinery
Mainlube 175 Synthetic Race Oil SAE 10w60 (engine)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff)
www.Mainlube.com.au
Mainlube is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2010, 11:55 AM   #5
Cav
HUGH JARSE
Cav's Avatar
Thanks boys for your interest.
