12-09-2010, 02:59 PM | #1 | ||
Blown DJR
Just wondering if anyone knows where you can purchase a wall mounted tyre/wheel storage rack in Brisbane.
DJR320 build No 2 |
12-09-2010, 04:59 PM | #2 | ||
Performance moderator
I think you'll find it's easier to make your own with some tubing and car stands ??
Weld a larger dia pipe on stands then mount the tyre support bar through ... It will be height adjustable and can be used latter as stands...
12-09-2010, 11:07 PM | #3 | ||
NECO
Here's something you can consider, it's not wall mounted though but do provide great protection.
Carcoon Tyre Garage |
13-09-2010, 05:35 PM | #4 | ||
I would recommend building one yourself, if you can weld build a steel one.. if not even timber would probably be ok.
13-09-2010, 07:18 PM | #5 | ||
DJR Fan
Or maybe from 100mm plastic sewage piping - all the angled adaptors just need to be glued together.
BTW what would be the best way to store tyres with out them deforming - resting on side walls, or hanging on the bead , or the tread sitting on 2 pipes , or make a cradle the same curve as the circumference and then on two pipes? |
14-09-2010, 08:13 PM | #6 | ||
I use brain. Not hip.
If you have 17" I will be taking one off my car trailer as I am switching to 18" on the race car. It locks too.
It is 50mm square steel To mount it on a wall you would need to weld a few tabs on where you want to mount it. |
14-09-2010, 11:48 PM | #7 | ||
regards Blue |
