Travis - 1999 Ford AU S1
Hi, I've just literally ripped out my old grey S1 Forte carpets for a full interior conversion to a black SR interior and was wondering if I should put some extra sound deadening on the floor of my car before the carpet goes back over the top of it, whether it be paint on or spray on sound deadener, sheets of it or sound deadening foam. What works the best in your experience and is value for money on a budget?
The Monty
you can just go out and get Dyno mat you pretty much pay for quality at the end spend $3 get a product that doesnt really work. in saying that there are products out there on ebay and occasionly pop up in autobarn are from the main makers of top brand sound deadners just with out the logo or brand name on the sheets and is usualy half the price.
id stay away from paint on one, as its messy as helll and hard to get an even coverage same as foam it expands more and cant really get an even coverage and since its going to be under the carpet not really the best feel or look |
Anyone have any idea what Dynamat costs roughly and what sort of quantity or amount you get (and from where)?
there was a guy in here just recently whom was sell generic branded dynamat for about half the price , i'll see if i can find the link
http://www.fordforums.com.au/showthr...sound+deadener here ya go
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
Former BTIKD
![]() Join Date: Mar 2005
To get the most from any sound deadening you will also need to do where the carpet goes up the fire wall, doors and behind the rear seat.
#6 | ||||
You can't stop the signal
There are better products out there than dynamat. Look for something with a dimpled face as it gives better performance.
Also use aluminium tape on all the joins/edges of the sound deadening. Quote:
![]() ![]() Cheers
#7 | |||
Former BTIKD
Irregular member
Dynamat was about $35 to $40 a roll from memory.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
#9 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
Petro-sexual
Dynamat is used to add weight to a panel to make it vibrate less, and is best used on flat panels. Highly curved panels are already very stiff and wont vibrate as easily.
Sound barriers (Mass loaded vinyl) are best to stop external sound transmission to the cabin. Normal underlay felt type stuff is probably better than Dynamat in this instance. Dynamat can be added in much smaller amounts, than generally seen, to achieve the same result. This place explains a bit about the different types of sound proofing... www.sounddeadenershowdown.com |
#11 | ||||
It's what is in the pictures before, and what I used on the inside of my ute. However what I used (770mm x 680mm section) isn't available to the public yet. They are still working out packaging for it. If needed I could get some for people, or try and sort out a group buy. The last I heard was they were going to do a 10 sheet box, that was going to be around $350/400 + gst. Cheers
#12 | ||
Thanks
#13 | |||
not here much anymore
RAM 1500
