24-08-2010, 05:51 PM | #1 | ||
Hi, can anyone help with measurments where to drill the four holes to mount an xr type wing on an AU1 boot lid?
Also how to remove the rubber strips above the sill to fit side skirts? any help appreciated. |
24-08-2010, 06:02 PM | #2 | ||
Lost Boost Gained Class
mate the markings are already there for the holes u just gota drill them out thats all i did to my old s1 to for a s2 XR8 wing
2006 BF Fairmont Ghia
2001 AU Falcon |
24-08-2010, 06:45 PM | #3 | ||
i think the skirts tuck under the rubber strips
26-08-2010, 10:57 AM | #4 | ||
Spoiler now fitted.
thanks for your replies. |
26-08-2010, 11:04 AM | #5 | ||
Just pull up really hard on the rubber strip from one end - it just clips in, so should come out reasonably easily.
28-08-2010, 10:51 AM | #6 | ||
Just realised i didnt wire the rear light. do i need to drill an extra hole and where does it get the power source from?
thanks. |
28-08-2010, 12:05 PM | #7 | ||
Drill a hole between the hole for the bolts, feed the wire into the boot, then through the rubber tubing/grommet setup at the right hand side near the rear window, then splice into the high mount stop light circuit, and remove the bulb from your existing high mount (you can only have 3 brake lights).
28-08-2010, 01:33 PM | #8 | |||
Flairs - Truckers Delight
Don't ask me why that is because my commodore has 4 brakelights.
28-08-2010, 04:12 PM | #9 | |||
Former BTIKD
