Old 10-08-2010, 01:22 PM   #1
Pazuzu
Default Getting doors of a Mk 2 Escort
Hi All.
I'm in the process of dismantling my doors, and I've noticed a couple of door hinge pins missing. I thought that while the doors are apart, I might as well take them off & clean the hinge assemblies etc. I was wondering if anyone can give me any tips on removing the intact door hinges? I can't see any obvious starting point for getting them out.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2010, 11:27 AM   #2
Jaycees
If you remove the centre pillar trims in a 4 door you will find the 13mm nuts that hold the hinge on and if you remove the front inner kick trim the nuts are also in there for the front door and up high behind the dash panel inside the door pillar you will find the top nuts
Jim
Jaycees is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2010, 01:15 PM   #3
Pazuzu
Thanks Jim.
Old 14-06-2015, 06:18 AM   #4
Ekkie
Default Re: Getting doors of a Mk 2 Escort
Hi, Can anybody help me with how to repair worn escort mk1 hinges. thanks
Ekkie is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 11:00 AM   #5
dirty hands
Over Thinker
dirty hands's Avatar
Ekkie.... stop asking hard questions
you may be able to find the hinge pin
this ebayer has a lot of mark I doors so may have hinges ?
http://www.ebay.com.au/itm/Ford-Mk1-...item3ce7aa5dfe
the australian ford escort parts supplier we used to use closed up shop
source of a new hinge would be the UK possibly
My car goes Brumm Brumm
Old 14-06-2015, 11:32 PM   #6
jpblue1000
jpblue1000's Avatar
Or use 8mm bolts and nylocks like I have. makes future removal that much easier.
Unless the hinge itself has worn oval or oversized then its a bit harder but try running a 9mm ream through them and 9mm bolt.
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2015, 09:42 AM   #7
Ekkie
Hi, Thanks for your help. It is the holes that are slotted so guess I'll go for the 9mm bolt idea. Thanks again.
