Old 15-05-2010, 12:51 AM   #1
frd906
Default Wiper motor, Replacement How To
Hey guys is there a doco on changing the wiper motor over, as mine has died,
Can just hear the relay clicking but theres no movement at all, it was all pluged back in properly and all the fuses are fine, any help would be gratefull
Cheers matt
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2010, 12:59 AM   #2
frd906
http://www.fordforums.com.au/showthr...ht=wiper+motor
Cheers guys, the thread above has solved my issue, as in the pics in my build thread i had the fuse panal out, so i will have to get the car home, HOPEFULLY SOON, to sort it out
cheers
Old 15-05-2010, 01:18 AM   #3
frd906
also i forgot to add, the washer bottle squirters work fine so im assuming its the motor it self and not fuse or wiring problem, every works fine blinkers etc work fine just that when i use the wipers i can hear the relay clicking but nothing
