15-04-2010, 11:30 AM | #1 | ||
Hi All.
Just purchased & received a new air filter assembly online. There is one port on the underside of the assembly, 13mm outside diameter & about 10.3 internal diameter. Can anyone tell me which hose should be connected here? Or should I just block it off? |
15-04-2010, 01:26 PM | #2 | ||
Oops- on a 2L Mk 2, standard 32/36 DGAV. Just replacing the old blue assembly, with big black air funnel & vacuum pump. There's a hose running from that to the old air filter, as well as a hose from the oil filler cap, and another hose running away from the filter to the carby or inlet manifold. As I'm getting rid of the old assembly, I won't be running the hose that goes from the vacuum pump to the thermo switch.
My question is: should I keep the hose from the oil filler cap connected to the air filter? Or should I run the hose from the air filter to the inlet manifold? Or both? Or neither? |
15-04-2010, 02:08 PM | #3 | ||
You don't need to keep the one from the oil filler cap connected although it is part of the emissions equipment so it would be "illegal" without it. Taking the hose off just lets gasses escape into the atmosphoere and will give you a dirty as engine bay.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
15-04-2010, 04:42 PM | #4 | ||
Thanks for that. I was thinking about just plugging the cap with a bit of tapered Delron. Any advice on the hose going from the filter to the inlet manifold?
15-04-2010, 04:56 PM | #5 | ||
arrrrr i don't know. Mine was removed years ago before i owned it and my manuals at home. Give these guys a call.
Small Four Spares on 02 9603 5333 Moorebank Auto on 02 9822 8422 These guys know their stuff when it comes to Eskys, anglias etc etc and between them could supply any part you need. Tell Brian at Small Four Spares Mat Dawson gave you the number if you call. He should look after you
16-04-2010, 02:08 PM | #6 | ||
All sorted- I think.
The hose from the old assembly will be chucked, as I won't be running that ridiculous black-armed vacuum pump anymore. The hose from the oil filler cap will be connected to the new assembly. The 3rd hose runs to the emission control spaghetti (not the inlet manifold- I kind of got lost), which I'll just block off. Thanks for the numbers Fev. I'll be sure to give them a call. |
