Old 04-02-2010, 11:25 AM   #1
gaz084
F1D procharged ute
gaz084's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: With the amount of detail Gareth has put into his BF heat exchanger by-pass modification ... and also his work on his supercharged BA EGAS build thread has been a help to many on this forum when it comes to DIY inginuity.
Thats odd.......how do u know its 170rwkw was it tuned?
My f1d Procharged Build Thread
http://www.fordforums.com.au/showthread.php?t=11283622
gaz084 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 11:30 AM   #2
RG
Back to Le Frenchy
RG's Avatar
It seems low but there are a number of reasons that could cause that, not the east of which is the dyno and the operator.
A test drive would be the only way to see if it has as much as it should.
Old 04-02-2010, 11:34 AM   #3
sd1800
It does seem abit low. I would expect 200rwkw in manual maybe 190rwkw in auto.
If it still has the AU1 XR8 19lb injectors it might be a conservative tune? Also the single 2.5" for a stocker is good but might be restricting the top end on a worked motor?
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 12:16 PM   #4
sd1800
For an auto it wouldn't be far off 90k at the rev limiter.
As i said the 2.5" single exhaust would be good for low down torque but probably shaves a few hp off the top end. As you would know Dyno's can vary alot too.
Now......
- 302rwkw
2019 Escape St-Line
Old 04-02-2010, 01:52 PM   #5
Stattic
Stattic's Avatar
I reckon a single 2.5 is strangling it
remember high stalls make less power on the dyno generally
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 09:06 PM   #6
CFOUR
The Destroyer
CFOUR's Avatar
Sounds about right for an auto. Should gain 35ish kw with a manual conversion
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 09:09 PM   #7
CFOUR
The Destroyer
CFOUR's Avatar
Also- for the most part a larger cam will mainly add torque, kw gains will be minimal.
Old 04-02-2010, 09:23 PM   #8
Ride
Stay Classy ™
Ride's Avatar
The stock cam isn't that far off what you'd find in a Series 2 200kw motor so I wouldn't be suprised, but for sure the exhaust is what's holding you back, even with the larger pipes the pacemakers have. I've got a single 2.5" system attached to a stroker and I'd be estimating I'm losing 20-30rwkw because of it, it isn't by choice but because of my financial situation.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2010, 09:26 PM   #9
Ride
Stay Classy ™
Ride's Avatar
Not a chance. 20kw if you're lucky and are pumping over 230rwkw. Take a look at some of the dyno results between the T3 guys, while there is a difference you'd be hard pressed for a difference of 20kw between the lowest auto and highest manual provided the same exhaust.
Old 05-02-2010, 12:04 AM   #10
CFOUR
The Destroyer
CFOUR's Avatar
You'll find that drivetrain loss is exaggerated with mods.
Also you're expected gains from a free flowing exhaust are optamistic at best.
Old 05-02-2010, 01:02 AM   #11
illusivedreams
Opimistic I would say,
Please note my opinion is not worth ******** when it comes to dynos.
Au Falcon Ute S2 2001
Lowered on Kings with Bilistien Shocks all round
2.5inch cat back
K&N Panel Filter
FG XR6 17" Rims 245/45-17 tyres
XR6T Snorkle
BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads
Tow bar
Transmission Cooler
illusivedreams is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 01:26 AM   #12
CFOUR
The Destroyer
CFOUR's Avatar
Reguardless of dyno's the au xr8 automatic gearbox is garbage the t5 is a much better option. The t3 manual gearbox is not a t5 btw.
Old 05-02-2010, 05:28 PM   #13
Dacko
Westie
I've just hit 170kwrw from a au2 fairmont ghia 175kw standard but with the following mods,ipv extractors into a 2 1/2 single right through,yella terra cold air box,and a custom dyno tune.
2000 auii fairmont V8 ghia
1987 Toyota Celica st165 GT4
1988 Ford Sierra RS Cosworth
Dacko is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2010, 05:29 PM   #14
Dacko
Westie
Sorry and its a auto
Old 05-02-2010, 06:17 PM   #15
SLO AU XR8
For a start, the T/B is way too big. HP-F have been known to have less the acceptable tunes by some members here too.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2010, 02:00 AM   #16
Ride
Stay Classy ™
Ride's Avatar
Sounds about right, I pulled 147rwkw on an absolute stock 175kw motor. The intake and tune would have made the difference but a more free flowing exhaust would have given you a larger increase again esp. if the tune was done after the mods.
CFOUR: Well aware the T3's use a TR3650 manual box, if anything the drivetrain loss would be less than the T5 and increase the gap between the auto and manual. If the auto gearboxes are 'garbage' then why did Ford have to have the T5Z in the 220kw XR8 and then the TR3650? The T5 couldn't handle decent power whereas the BTR (although slightly different revisions) have been used with T3's making good power and the majority of the BA range.
Old 06-02-2010, 11:39 AM   #17
xr8ute
Back on the road
xr8ute's Avatar
The cam is small, and the intake is big, and the throttle body is really big....that combo is a real mismatch.
Its also hard to know just how well the GT40Ps have been ported unless you have a flow sheet for them?
Can you confirm which Trickflow intake it is? I would imagine its either a track heat (12.2" runners) or Street Heat/Street Burner (15" runners). Both only have a 75mm opening for the throttle body so i guess that was machined out for the 80mm throttle body.
IMO the street version with the longer runners would suit your combo better, but even better still would be the std Explorer intake and std 65mm throttle body.
Unless those heads have been incredibly well ported, then you are going to need a much larger cam to make 200rwkw.
Old 06-02-2010, 02:06 PM   #18
Windsor220
Now Fordless
Windsor220's Avatar
True the autos are slower and absorb a bit more power but after a couple of mods to a standard 220 XR8 and your already over the T5s torque limits. Not a very strong box.
Old 06-02-2010, 05:17 PM   #19
Stattic
Stattic's Avatar
Why spend so much money and buy a crap exhaust lol
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 06-02-2010, 05:32 PM   #20
Stattic
Stattic's Avatar
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 06-02-2010, 05:53 PM   #21
stavros68
Change the injectors to 24lb
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2010, 05:56 PM   #22
b2tf
not here much anymore
b2tf's Avatar
Sounds about right for the mods you have listed. My old AU3 had a twin system, Alloy heads, 621371 cam, 70mm TB and intake and a few other things (it was based on a 200 motor) and only ever made 180rwkw - on the street it was a different story though.
2024 F150 XLT
Old 07-02-2010, 12:58 PM   #23
b2tf
b2tf's Avatar
Originally Posted by Blake_7
jeez i thought with twin 2.5'' inch exhaust,24lb injectors and a retune it would make 190-200rwkw but who knows
Most people on here have 'inflated' views of what kws cars should be putting out but they are only a number. I was so disappointed with mine when I saw it pulling those numbers - thought I'd wasted my money on stuff that didn't work well together and was bitterly disappointed - until I took it for a drive. Don't worry about the numbers - drive it before you pass judgement.
2024 F150 XLT
Old 07-02-2010, 04:35 PM   #24
Stattic
Stattic's Avatar
bigger cam, bigger exhaust, retune?
Current
Blueprint 03 xr8
256rwkw
BA manual Typhoon
The old ride....
Old 07-02-2010, 04:53 PM   #25
RG
Back to Le Frenchy
RG's Avatar
well all i took it for a drive and the mrs too seeing as though its her new daily, felt quick for what it was, hard to compare to my 290rwkw fg turbo but yeh it felt good so we put a deposit on it.
what to do first change injectors and do a twin 2.5inch exhaust and get it retuned or do 3.9 diff gears......
I'd make sure all ignition components are in order and then go squirters, exhaust and a tune.
Old 08-02-2010, 07:54 AM   #26
xr8ute
Back on the road
xr8ute's Avatar
ok so i spoke to the guy again the car is running a single 2.5'' inch exhaust and 19lb injectors with a soft tune
The soft tune is necessary becuase of the 19lb injectors. They would be maxed out.
Russ makes a good suggestion; check the condition of the ignition system consumables, change exhaust, change injectors for 24lb/hr and then retune.
Your tuner should be able to load a tune onto the box for you, in advance of changing the injectors, to flash as soon as they are fitted (you shouldnt drive the car with 24's if its still tuned for 19's).
