Old 07-11-2009, 08:46 AM   #1
nuckenfutsmk1
Default Crack in head 2 LTR BALLS UP
Removed my head to find there was a visible crack between the two valves in number one. Would you say that it needs to get the *** or will be right for a little time. As money is a little issue at the moment its more just to get it rolling. In the future a proper head will be detailed. but for know will it last or detonate. The bottom end has 60 thou over pistons that i dont want to destroy this is my other concern.
What do you think
nuckenfutsmk1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 05:36 PM   #2
dawi
Hi, in all my experiences with engines: If it has visible cracks or damage its not worth your time and effort in putting it together and risking a more serious failure with bent valves etc. Not worth risking the disappointment.
You'll spend a day or so putting it back together and need to buy a new head gasket will cost you some $$ and time.
I'd also go to an engine workshop and ask their opinion, then you can get a free quote and go from there.
Good luck with it
dawi is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 07:03 PM   #3
Les
Mk2 Racer
Les's Avatar
You could take it to an engine specialist and have it repaired but that is not to say it will last. Usually only a last resort for heads that are hard to find. 2 litre motors are still around, I'm sure someone near you has a head thay will part with at a reasonable price. pm me if parts are too hard to find. Don't blow your engine for the sake of a head.
Les
Les is offline   Reply With Quote Multi-Quote with this Post
