19-05-2009, 11:23 PM | #1 | ||
Well i picked up a te cortina to make into a burnout car...
and i wanna put 5 stud front end on it.. was thinkin if any x seris front end will fit on it?? Cheers :1syellow1 :1syellow1 |
21-05-2009, 06:03 PM | #2 | ||
Hey BOXCAR,
I don't think that anything of any X serise car fits regarding suspention. I know that there was a brake upgrade that was dropped due to it being able to lock on without warning. The reason is that the suspention on the corty has nothing in common with the falcon stuff. The cheapest way is to ethier get a hopper stoppers kit or get some blank rotors and get some one to drill them as a 5 stud. But i think that you will need a spindal mod to fit the rotor as i don't think you can get blank cortina rotors.
Current Project: Rebuilding my Corty! 220kw Au3 XR8 Engine, full Custom Zorst, EMS Computer, Underdrive pulleys and MSD coil Parks. TKO Tremec 5 Speed Full Floater 9in 31 Spine with locker Its almost there!!!! |
25-05-2009, 04:55 PM | #3 | |||
Cheers : |
26-05-2009, 10:53 PM | #4 | ||
71 Mk2 Cortina owner
you could always use a hub adaptor! its like anyother adaptor eg pre au adaptor, but instead of being the same pcd on both sides the other is different ie 4x108 on other side 5x114.3
Need any tiling done? no job too small competitive rates anywhere in adelaide. pm me or give us a call on 0418850384 |
29-05-2009, 09:08 PM | #5 | |||
Its not gonna b for onroad use.. its for burnout track only |
04-06-2009, 10:08 PM | #6 | ||
I think its impossible to get this config. of spacer adapter the holes are too close together.
