Old 04-03-2009, 09:08 PM   #1
DZFord
DZFord's Avatar
Default Help! Where would I get these from?
When installing some headers on the duratec engine, a CEL (check engine light) comes on. It is due to the second exhaust oxygen sensor complaining about altered airflow due to the installation of more-efficient headers or a high-flow cat (or both). Whilst it has no effect on the engine, it's kind of annoying just sitting there all the time, plus, how would I know if something else is actually wrong with the engine (besides pulling the error codes)?
There is such a thing as a "cheater harness" that simply plugs in to the existing circuitry and eliminates the CEL. european-parts has an example, but this does not work with the x-force headers/cat: HERE (but this is for a de-cat setup)
There are some others too, HERE and HERE, but these are for the Zetec engines.
So, my alternative is a spark plug anti-fouler / non-fouler modification to the 02 sensor, which basically keeps the 02 sensor in the exhaust system but uses a spark plug fouler attachement to slightly remove the sensor from the stream of exhaust gases and therefore correcting the readings.
Here are some links to see how the modification is done: FIRST and SECOND
Now, here is my question: where on earth do I get spark plug non-foulers from? None of the guys at my local Bursons knew what the hell I was on about!
By the way, they need to be 18mm non-foulers and I think the universal part number required is 42002 or 42009.
DZFord is offline   Reply With Quote
Old 04-03-2009, 09:28 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
I found these two amazon listings
http://shopping.bit-tech.net/us/prod...lug-non-fouler
And ebay
http://shop.ebay.com/items/?_nkw=non...uler&_osacat=0
The third way is with a custom tune. When you get a tune, the tuner can switch off the o2 sensor
I'll keep looking.
In Australia, I'd try Repco or Bursons
melbzetec is offline   Reply With Quote
Old 04-03-2009, 09:32 PM   #3
DZFord
DZFord's Avatar
Thanks mate, I'll check that link.
I've always been considering a custom tune, hopefully my car will end up a Herrod's one day! I'll just need to save for that...
As for Bursons, they nearly laughed at me, as if such a part didn't exist!
Old 04-03-2009, 09:36 PM   #4
melbzetec
melbzetec's Avatar
I've updated the links Dan
Old 04-03-2009, 09:42 PM   #5
DZFord
DZFord's Avatar
Thanks again, that'll keep me busy for a while.
Frustratingly, it looks like the 14mm non-foulers are more common than the required 18mm's.
EDIT: amazon.com won't ship it to Australia and the amazon "featured merchants" quote $100 shipping!
I've emailed a few of the international sellers on ebay and will see if they'll mail to Australia.
Cheers.
Old 04-03-2009, 10:14 PM   #6
melbzetec
melbzetec's Avatar
If it helps, the HELP! brand part no. is 42002. That's the 18mm tapered
Old 04-03-2009, 11:03 PM   #7
DZFord
DZFord's Avatar
Thanks Steve, purchased it through good old ebay!
2 adaptors at $2.99US each = a very cheap mod! Shipping will be $14US, priority post.
Old 06-03-2009, 06:58 PM   #8
Mullett
Badly Focused
Mullett's Avatar
If that doesn't work for you, let me know and I'll machine you one out of billet bar stock.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote
Old 06-03-2009, 08:25 PM   #9
DZFord
DZFord's Avatar
Thanks mate! I'll let you know if I need a hand.
Old 18-03-2009, 10:24 AM   #10
wallabies
did you end up getting the part to stop the check engine light to go off?
wallabies is offline   Reply With Quote
Old 18-03-2009, 10:29 AM   #11
BlackLS
yum
http://www.european-parts.net/catalo...roducts_id=942
2005 LS Focus LX
250,000kms.
BlackLS is offline   Reply With Quote
Old 18-03-2009, 11:58 AM   #12
DZFord
DZFord's Avatar
Yeah I purchased the o2 cheater harness from european-parts and it didn't work. As they state, it is probably more for a decat setup. If I had known about the spark plug fouler trick I would've tried this first before spending on the harness + freight!
As for the fouler trick, I haven't had time to install it yet and I also need to go and buy some anti-seize lubricant first. I'll update here and let you know if it has worked.
