Old 22-02-2009, 10:35 PM   #1
CMYAU3
Tyre Shredn
CMYAU3's Avatar
Default intake question
hey guys im putting on a snort kit now with the plenum
but it obstructs this little doo dad.
this controls all these butterfly valves but wtf do they do???
wat would the effects be if i removed the butterflys all together???and the doo dad also
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2009, 10:45 PM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
They're the butterflies for the short/long runners in the BBM and I believe that doo dad thingy is the actuator for them.
Being turbo, I'd be gutting the BBM and removing that stuff while you've got it apart.
Old 23-02-2009, 05:45 PM   #3
CMYAU3
Tyre Shredn
CMYAU3's Avatar
do all the butterflies work like a choke? i dont know what they do.
if i remove them will be a to start when cold and run crap until up to temp???
Old 23-02-2009, 06:55 PM   #4
private9
private9's Avatar
No. Butterflies are used to switch between the runners in the manifold. Long runners at low rpm for torque, then IIRC they switch over to the short runners for more top end power at roughly 3800rpm.
Old 23-02-2009, 08:06 PM   #5
CMYAU3
Tyre Shredn
CMYAU3's Avatar
ohhh k thanks for that its gud to know
Old 23-02-2009, 08:27 PM   #6
private9
private9's Avatar
No probs! I wanna gut mine if it's not already! Hopefully it's easy to do.
Old 23-02-2009, 08:31 PM   #7
RG
Back to Le Frenchy
RG's Avatar
Yep, with a turbo they are pretty much pointless. Remove them and do a little porting while you are there.
Old 25-02-2009, 11:44 AM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
yep I allready have done it justin!
Don't bother there will be limited or no gains with such a low boost set up.
As for your other thread about changing injectors... a couple of questions.
1. Are you running a aftermarket ecu??
2. Are you running a rise of rate FMU (fuel regulator).
If you are not running a after market ecu the stock computer can't handle bigger injectors without a flash tunner even then the capabilitys are very limited. Also you can run a max of 9psi only as any more the map sensor will shut down the whole system.
If you have any Q's or anyhtingt feel free to PM me and im happy to help out.
Tristan
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
