Old 02-02-2009, 10:38 PM   #1
R0BD0G
R0BD0G's Avatar
Default Escort mk1 / 2 Tie Rod Ends
ok well im wondering wether the tie rod ends on mk1 are different to mk2?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2009, 10:41 PM   #2
mickas
yes they are.
mickas is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2009, 01:45 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
A very vague memory tells me Mk1 imperial sizes and Mk2 metric - or am I confusing this with something else?
Old 13-02-2009, 09:05 PM   #4
R0BD0G
R0BD0G's Avatar
its prolly right. um. well i have the new ends now anyway for a mk2. when the wheel alignment was done on mine they said that the tie rod ends wouldnt tighten coz they were the wrong size. so yeah. hopefully that fixes the prob. its coz the 4 piston brakes use the mk2 hub
Old 14-02-2009, 02:55 PM   #5
Puzzlescort
Rally Nut
Puzzlescort's Avatar
the tie rods are the only things you need to change when putting MK2 struts into a Mk1, lower ball joints & sway bar etc are all the same
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2009, 08:12 PM   #6
whooligan
whooligan's Avatar
Only the early Mk 2 struts will fit a Mk 1. Late ones, you have to change the strut top as they are smaller on the later Mk 2 models.
Mk 1 tie rod ends will not even fit/let alone tighten up on a Mk 2 rack. The thread is completely different.
You can get what they call "green" tie rod ends which have the later course thread to fit the Mk 2 rack, but the smaller tapered end to fit the early struts (ie Capri struts). An easier option is to just fit a Mk 1 rack.
whooligan is offline   Reply With Quote Multi-Quote with this Post
