Old 10-01-2009, 02:16 PM   #1
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Default Help!!! Engine cutting out while driving!!!
Disconnected the battery and took it out to clean a couple of things in engine bay, flush out some electrolyte corrosion.......put everything back in, turn engine on, put in reverse, idle revs drop dangerously low......driving along, stop at lights - idle is low, car shaking..........turning corner, engine stops completely!!!
Happened another 2 times where it cut out, I was only driving around the block!!!
What's going on??? I didn't get any electrical stuff wet - was only flushing out corrosion under the batter holder!!!
Any help would be appreciated!!!
Cheers Dave
Old 10-01-2009, 02:37 PM   #2
adrian k
adrian
adrian k's Avatar
My XR6 did that once, turned out to be a stuffed idle bypass control valve. if you lucky yours might just be sticky. take it off and give it a clean and oil.
but given that nothin else has changed, just the battery has been disconnected, it may just be that the ECU needs to learn the throttle positions again. not sure about the AU I6, but the EF needed to go thru a procedure to reset the throttle positions after the battery was disconnected.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2009, 02:38 PM   #3
Dave_Obsession
the car was driving perfectly beforehand.......so you think I should just reset the ECU???
Old 10-01-2009, 03:16 PM   #4
The Monty
Just slidin'
The Monty's Avatar
You havce disconnected the Battery which in turn HAS reset the ECU. Give it 100km and it will have relearnt everything and it will be fine. Mine when reset idles really low as well, and has stalled, so dont let it stress you. Get it out on the highway, give it a bit of a flog, go home and see how its running then.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 10-01-2009, 03:49 PM   #5
Dave_Obsession
Thanks Monty, I hope you're right.....I don't see how it can be anything else....still.....im new to a lot of this stuff......only started taking an interest in it all recently....still a bit green around the ears!
Took it for a 10 min drive......stalled another 4 times :-(, but the idles weren't dropping as often as they were the first time.........when it happens its almost always under braking from 50km/h+.....revs drop down to just over 200.....sometimes it stalls.....sometimes it doesn't...
So you reckon about 100kms?? Is that under various conditions of driving (fast, slow, stopped, corners, cruising) or would a freeway trip be enough for it.....
Old 10-01-2009, 04:23 PM   #6
The Monty
Just slidin'
The Monty's Avatar
Just drive it like you normally would.
Old 10-01-2009, 05:19 PM   #7
bodes-sh
*sigh* here we go again...
disconnect the battery again, leave it for about 10 mins, then,
start car and let idle 2 min in park a/c off,
foot on brake, and idle in drive 2 min a/c off,
idle in drive 2 min a/c in,
idle in park 2 min a/c on,
the drive under various throttle conditions for about 10 mins and it will be fine
Old 11-01-2009, 02:35 AM   #8
EvilChief
Boost Addict
gotta love it, may as well sticky it, as it comes up ever 2 to 3 weeks :togo:
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 11-01-2009, 11:02 AM   #9
bodes-sh
yeah, i reckon so...
just had a look and it's in here anyway... http://fordforums.com.au/showthread.php?t=11244844
Old 11-01-2009, 12:41 PM   #10
Dave_Obsession
cheers to everybody who helped me out!
Old 11-01-2009, 01:16 PM   #11
The Monty
Just slidin'
The Monty's Avatar
So it all worked out?
Old 13-01-2009, 01:15 AM   #12
Dave_Obsession
well its been 150kms since the reset, and whilst it's not 100% perfect yet, it complains less and less each day (presumably as the ECU learns more and more). All's well that ends well, I suppose, cheers monty!
Old 08-11-2020, 02:43 PM   #13
Bazza1957
Default Re: Help!!! Engine cutting out while driving!!!
So what happens when it's a manual..so what's the reset procedure then ???
Bazza1957 is offline   Reply With Quote Multi-Quote with this Post
