Old 17-12-2008, 09:25 PM   #1
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Default p/window circuit breaker buzzing
Hi guys,
driving home today when suddenly I got a load buzzing noise coming from the fuse box under the dash.
Found the cause to be the power window circuit breaker and it was VERY HOT.
I pulled it out and got a replacement from Sprint, didn't solve the problem.
Also worth mentioning that while this buzzing is happening the power windows don't work.
Any clues?
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2008, 10:17 PM   #2
GTBenny
GTBenny's Avatar
What your referring I don't think is a circuit breaker. Is it a fuse or relay? If you have a buzzing sound then I would think you have a high resistance joint or faulty relay.
Benny
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm.
GTBenny is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2008, 12:03 AM   #3
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
I had no idea it was a circuit breaker until I showed it to the bloke at Sprint,
who then checked with the senior bloke.
I bought a replacement which was clearly marked as a circuit breaker,
it fit where the other one had come from and the power windows worked fine until the buzzing started again.
BA MK2 XR6T
Old 14-02-2017, 08:53 PM   #4
AUte
Default Re: p/window circuit breaker buzzing
Thread Digging - but this is exactly what is hapenning to my AU Fairlane - did anyone ever solve this???
M@
Next Project - Looking for parts / donors for 79 F100 4X4 project
AUte is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2017, 11:52 PM   #5
snap0964
I know from experience a short to earth will cause the CCT breaker to act like this.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2017, 06:38 AM   #6
AUte
Thanks Snap, I will start to do some digging to find the short
M@
Old 15-02-2017, 01:07 PM   #7
snap0964
Yeah, intermittent faults are always a PITA to find.
