Has any advice as to the wiring up of a BARRA to an AU? fitting the engine looks pretty staight forward( except for the bonnet clearance issues, which will probably be solved by the use of fibre glass) but it's the electrics in particulare the ignition with have me completly stumped?
not here much anymore
It would be fair easier to simply add a turbo setup to your existing motor.
RAM 1500
g`day frank welcome to the forums, sounds like a good project, i`m not sure mate but if i recall previouse posts the barra computers is needed possibly the loom or parts of it, or after market computer , someone will correct me if i`m wrong, good luck with it.
Smile
Its very doable. You will need full wiring diagram to add wiring and use exisiting wiring.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#5 | |||
Sly like a G6
The AU's engine management uses the PWM communication protocol, the B-series uses CAN and the B-series ECU is linked to all the other alphabet soup of B-series computers, BEM, ICC, HIM etc. Apparently a B-series engine won't run unless they are all present. There was someone who could mod the BA ECU to work without all the other gear, but apparently it was too easy for other tuners to work out what to do from looking at his mods, so he stopped doing it.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
Cuban... nothing like it
Cost wise it would be a choice between an auction house turbo ba with strip down and rebuild and just using your current engine with a turbo
bpt motorsport in perth can disable all the auxiliary (ie, icc, bem, etc) security measures from ba ecu's with the sniper software i believe. as above, the hardest bit would probably be wiring the two looms together. you will need to have the au ecu in place so things like trans, dash, ignition, etc all still work, and a ba ecu under the bonnet to drive the motor. have a look at the sponsors section further down the page and ask them about it
Wow some say it's doable and some say forget it, maybe I'll do both! I'll put my FG turbo on to my VCT first and see how happy I am with that, and slowly work on the graft seperatly using a half cut from a wreckers and nut out the obstacles one at a time?
Hmm
Maybe a bit more background of what you want and where you intend to use it. If you are going to rebirth a car with a cut n paste and increase the power house to run a 10sec car, then a f6 with the good gear will give you the same thrill and a bonus as a daily driver Some of the older bastards, aka me being of them, will pass on experience that if you are going to spend 20k plus on a vehicle, let someone else do the development and enjoy the rewards at a fraction of the cost. Even a 3v is an untapped powerplant |
I've got a one owner car( I'm it's second owner) and it took me 18 mths and a lot of luck to find a manual, I'm absolutely in love with it, I've put brand new brembos on the front and have recently put it on VSI LPG and a great Pioneer stereo with blue tooth and ipod, a cousin of mine has a BA XR8 manual and (this is only my opinion) I reckon the AU IRS superior to the BA it's a lot less nervous with mid corner bumps in my opinion than the "control blade" that's my observation anyway, the only problem I have is there's a guy I run into on my way to work every morning who drives one of those TRD Aurions and he kicks my but every time in a very smug and arrogant manner and all I won't is a bit of payback if you know what I mean, I don't won't to set the world on fire I just would like to keep up with and maybe beat some of these newer cars that seam to have to wood on my AU
lmao...a raptor s/c kit is only just over 5k, then it's s/c like the aurion, lol
bit cheaper than an xrt motor conversion... just keep in mind though, unless you are prepared to throw a fair few $ at it, don't expect it to be cheap, fast and reliable....remember, you can only have 2 of those things...or so they say |
#12 | ||
Turbos aren't a mistery my brother has spent a few years in and around them and as for paying some one to work on my car that's just not in my nature I have a simple philosophy to my life "if I can't fix it I won't own it" that's why I have a manual what's the worst that can happen, a new clutch? rebiulding the box? if I can rebuild a L/CRUISER 5 speed and transfer case how hard can a Tremec be? I have no intention of putting more than 6 maybe 7 psi boost into this car if that's not enough to kick that AURIONs butt then I can accept that and just be happy with what I've got
by $ i meant engine more than anything. as for the s/c kit, it's diy. you bolt in all on yourself. sly has done this recently to his au, albeit an auto, but running lpg and 8 psi. i think this is rated at 350hp, i'm not sure if that's rear wheel or flywheel though... i guess a more accurate answer could have been provided if you said how much power you wanted out of it in the first place. as for rebuilding the t5, you would probably be better off getting a stronger box to start with. not that these are that weak, as long as you don't go slamming gears and dropping the clutch all the time it should handle the power you want fine
#14 | ||
350hp sounds about the ball park which would probably be in the "14s", a friend of mine has a VN SS with a paxton on it but to be honest I'm not a big fan, the power delivery can be (for me any way) a bit how can I put it brutal which suits my mate just fine as he likes doing the odd burn out or two, I'm not that way inclined any more I grew out of that faze about twenty years ago (my first car was my fathers XY wagon with factory fitted 302 & toploader, to which I had to add a 9inch to, tin hats and toploaders are a recipe for headaches as I found out) that's why I've chosen the turbo option plus an FG Garret came along at the right time and for a price that I couldn't knock back ($900.00 with injectors and blow of valve and not stolen), the Barra thoughts started about a week ago when I visited a mate and had a look at the engine bay of his XT Wagon and thought how hard could this be to fit into the AU? so I bought a 190 on ebay last weekend for $500.00 and so I thought bugger it I need something to tinker with on the weekends and here I am with this big arsed can of worms in front of me now!
#15 | ||
Sly like a G6
350hp @ the flywheel, around 260 @ the treads.
#16 | ||
well the motor conversion can be done. but you really need a bf (for the motor you have there) ecu to get the most out of it. then you need to find someone who can set the ecu up for you (ie remove security) so you can get it all running. from what i understand physically the motor bolts straight in but you will either need a high series (non xr) bonnet to clear the valve cover. i assume from that above post you are very mechanically minded, so it shouldn't be too hard. have a read through here http://fordforums.com.au/showthread....ht=ba+motor+au i know it talks about the au ecu, but you won't be able to run the dual cam timing with it, so it kinda defeats the purpose of it...
#17 | ||
Turbo your existing I6 au engine
#18 | ||||
Back to Le Frenchy
#19 | ||
goto snort performance.. get them to price up a complete kit minus the turbo/bits you already have
then goto atomic performance and get a full forged bottom end and stronger valve springs etc and upgrade your fuel system and get the edit or chuck in aftermarket managment and your sweet for over 400hp at the treads
#20 | ||
Fast Ford to the Future
by the time you finish, the guy in the Aurion is going to be taking a different street to you. Who cares about the guy in the Aurion?
CURRENT RIDE - 2011 FG XR6T Nitro 6sp Manual with Luxury Pack, 19 Inch Varrstoen 2.2.2 Matte Black, Herrod Intake
OLD RIDE - oZeCruiser: 1994 ED Falcon Futura |
#21 | ||
Just slidin'
350 hp will end up arpund a mid-high 13.
MD Mondeo - For the family
