#1 | |||
Back to Le Frenchy
Anyone had to do this to their IRS AU? One of mine is fairly twisted and I'm buying a replacement but I'm just after any tips or tricks. The Max Ellery's book I have says it is a pretty easy straight forward job but I refuse to believe that lol.
Believe it Russ, it's as easy as opening a stubbie at 12 O'clock on a Sunday arvo.
2015 FGX XR8 5.0 S/C 645 RWKW ![]() |
#3 | ||||
Back to Le Frenchy
This may turn out well after all.
#4 | |||
Back to Le Frenchy
Apart from the CV joint itself are there any other bits I'll need?
NOPE, it really is easy mate, just be carefull when inserting into the diff housing not to dislodge the axle seal.
#6 | ||||
Back to Le Frenchy
MADED.6
yeah ive had mine apart to do wheelbearings a few times and they really are easy.
where are u getting urs from as one of my driveshafts are bent and it causes a vibration. also be careful with the driveshaft sometimes they can get stuck in the hub dont hit the end of it put a piece of wood in the way if its getting caught. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
#8 | ||||
Back to Le Frenchy
Mine will be coming from eBay, reco'd one for $165.
#9 | |||
Back to Le Frenchy
Well what a drama. After deciding against the eBay shaft for
a) it's an eBay shaft and b) I need it NOW I went about trying to find one from anywhere but Ford. It soon became apparent that no one makes them, I can get heaps for a 6 cyl but they apparently won't last 20 minutes behind an 8. Fortunately for me Craig from RAPID PERFORMANCE put me on to a bloke that had a second hand one, s/h is good for me as I reckon it won't be the last one I twist. $150 later for the shaft with a hub on it and I am done. I'll whack it in on Sunday and test the 12 o'clock beer theory ![]()
Mate, if you haven't done the one side in under 3 hours you will need lots more beer!
ill have to take mine out when i drop the lsd in the coming weeks, is it as simple as undoing the bolt on the lower control arm, and pulling it till it comes out?
#12 | ||
MADED.6
nah mate u have to drop the whole hub out well i had to anyway as it doesnt move enough to just pull out the back.
so undo the whole stub axle and drop it all out. cheers josh.
#13 | ||||
Back to Le Frenchy
Sound right?
#14 | ||
![]() Doesnt the circlip mean it will just pop out with enough force? |
#15 | ||
Yes what your book says sounds right russell, but then you will need to undo the large nut on the cv shaft going thru the wheel bearings 36mm i think to pull the shaft out of the hub/bearing.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
#16 | ||
FFS Russell, just get in there and give it a go mate.
Honestly, you can't really screw it up mate!
#17 | ||||
Back to Le Frenchy
There is no love for the AU in the aftermarket world.
#18 | ||
And don't forget the finishing beers
#19 | ||||
Back to Le Frenchy
#20 | |||
Back to Le Frenchy
Done, easy as.
Too bad that there is still a noise in the back but at least this has made it only half as bad lol.
#21 | ||
apart from being twisted how was the condition of the drive shaft ?
#22 | ||||
Back to Le Frenchy
