Old 31-08-2008, 10:11 PM   #1
Loris
Focus & Territory TDCi
Default Removing TDCi Engine Cover
Has anyone done this to their turbo diesel?
Its been mentioned that all you need to is lift the cover up vertically as it is just clipped in, this was said for the zetec duratec engines..
I tried the above but was not able to pull it up vertically, it feels like its bolted on somewhere but cant find where..
Anyone able to tell me from experience where the clips\bolts are located, and how many there are?
cheers,
Loris.
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2008, 10:23 PM   #2
RJO89
EuroFordClub
RJO89's Avatar
I wouldn't think it would be bolted on. There's four clips on it. On the four corners. The front clips should come off relatively easily, but the back ones can be tough to get off the first time.
Far from stock... --- SOLD :
Old 31-08-2008, 11:38 PM   #3
AnthonyTDCi
Focus TDCi
AnthonyTDCi's Avatar
yes i have removed it.
just have a feel around underneath it and there are about 4 clips. the cover just pulls off but take care when doing it.
AnthonyTDCi is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2008, 06:39 PM   #4
Turbodiesel
Torquer
Turbodiesel's Avatar
There are 3 ball clips that it sockets into, I'm pretty sure they are in the following locations: top left, middle right, bottom left.
It's pretty hard to pull off the first time but it will come off, a good idea is the grease up the balls it sits on so next time it should come of easily
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2008, 08:17 PM   #5
Loris
thanks guys ill give it another go
Old 01-09-2008, 11:19 PM   #6
Biggs
There is a rubber grommet on top of each "ball" which latches onto the bottom holes of the plastic engine cover. Make sure you don't lose them.
Biggs is offline   Reply With Quote Multi-Quote with this Post
