Focus & Territory TDCi
Anyone seen this?
![]() ![]() http://cgi.ebay.com.au/7-2-Din-Car-D...dZp1638Q2em122 you wouldnt need a double din fascia and you can still use the volume control under the steering wheel.. has anyone seen these advertised elsewhere, its a bit pricey?? |
See this thread on the Mondeo forum. Similar but would give you a quick overview.
http://www.fordforums.com.au/showthread.php?t=11230674 |
EuroFordClub
Just be warned that if you have an LT, the plug won't fit. It's a different size, and there are no adaptors for it. So you will need to cut and re-solder the wires...
Far from stock... --- SOLD ![]() Now riding a 2009 Kawasaki Ninja 250R ![]() |
ahh thanks, i think ill give it a miss.. i will just get the double din fascia and a proper sized double din head unit
There are similar units on Ebay for $Euro 515.00 at eurpoean sites.
Eat my Brake Dust
Actually I'm pretty interested in this thing does anyone know who the manufacturer is or what it is called? will help in digging up more info about it
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club ![]() ![]() |
EuroFordClub
Don't do it. Not worth it. Save the money and get a proper one. There's a few threads on this forum about these units and the general consensus is that they're c**p
Eat my Brake Dust
OK then.....I'm not really up with the head units so can I ask, what is there available that can just "plug-in" like this one? or where can i look for one? I don't like the idea of having to buy a face to fill in the gaps around the unit. in my opinon the after martket faces all look cheap.
EuroFordClub
You're not going to find a 'plug-in' one as such. They don't even make harness adaptors for the LT stereo. So if you replace anything stereo wise you need to cut the harness off and re-solder the wires.
if i disconnect the original head unit and reattach it will it ask me for a code? there is no code listed in my manual or anything..
EuroFordClub
Yeah it will. Also happens if you disconnect the battery for more than 5 minutes or so. Call your dealership and they'll be able to give you the stereo code.
#12 | |||
yum
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
Alternatively you could look in the glove box... There is usually a white sticker on the side with a serial number and barcode on it - and a 4 digit code at the end. Those 4 digits will be the code for your radio.
#14 | |||
When did you realise there was a sticker there? before or after your first service? Maybe they stick it on after a service.. |
#15 | ||
yum
Whats the point of a coded radio when the code can be had in an unlockable glovebox
2005 LS Focus LX
#16 | |||
Eat my Brake Dust
Hahahahhaah..... yeah I kinda though that myself when the dealer told me after buying my car.
#17 | ||
I had the sticker there since i bought it from the dealer. Anyway, if its not there, then its not there. I just thought it would be one of those things that every focus had. But it was a big relief when i tried the code and it worked!
#18 | ||
Which fascias does everyone recommend when doing a head unit change? From experience which looks the best?
Ive found these two on the net: http://fascias.com.au/product_info.p...roducts_id=129 http://caraudiosecurity.com/shop/pro...s_id/6802.html Anyone have any feedback or recommendations? Im after a double din one. |
#19 | ||
EuroFordClub
Never seen that second one before. Looks like it might fit in a bit more with the silver surrounds around the stereo.
I've got the same as the first one, which acts as a double DIN or a single DIN with a pocket. Here's a pic: ![]() Personally I reckon it looks good, but every has their own opinion.
#20 | ||
nice thanks RJO89.. that doesnt look to bad at all
![]() does it fit in pretty tight? any modifications to get it to fit in properly etc? how does it securely sit in place? |
#21 | ||
EuroFordClub
Yeah mate fits in nice and tight. The fascia itself has four clips on it, one in each corner. Then the pocket has a clip on either side, and then you mount the stereo bracket on the other pocket. Or in your case the stereo bracket would take up both spots. The stereo brackets have little tabs that you bend around the fascia that prevent it from moving. No modification needed. The main modification is cutting the stereo fascia and re-soldering the wires!!!
#22 | |||
Isnt there an extension for the wiring you can get? Im probably better off getting the extension wire and soldering the new head unit on to that, that way ill be able to put the stock one on pretty easily.. |
#23 | ||
EuroFordClub
Sorry the stereo adaptor. And if you have an LT there is not adaptor available. They've got one for the Sony head unit in the XR5, but not one for the stock Ford stereo. Annoying I know. So the only option unfortunately is to cut off the stereo adaptor and re-solder the wires. Then if you want to take your new head unit out and put it back to stock, you have to recut the wires and re-solder the new connections on. :(
#24 | ||
anything from this site work in regards to the stereo adapter? : http://www.nexxia.co.uk/Car_Stereo_f...ford/focus.htm
#25 | ||
EuroFordClub
Nah they're all the wrong one. The large square-ish ones that you see are the ones for the Sony head unit out of the XR5. I'll take a photo of the one that comes out of the LT soon and post it up here so you can see it.
#26 | ||
sweet thanks..
i went to autobarn yesterday and they suggested instead of cutting the plug just bridge it (make a slit in the original cable, push the insulation to one side and connect the cable directly to the original, then solder) i think ill be going down this path. |
#27 | ||
hey RJO89, any luck with getting the pic?
also did you take note of what colour wire goes where by any chance? |
#28 | |||
EuroFordClub
My suggestion: Cut the wires off, but leave enough length on the plug to re-solder if you decide to re-connect the old stereo. Here's a few pics of the plug. Little bugger of a thing ![]() ![]() ![]() ![]() There's a thread on here somewhere about the wire colours. I'll try and find it for you Loris ![]()
#29 | ||
EuroFordClub
Got it - Courtesy of Skriblz06's brother!! Cheers Scriblz!!!
The colour codes on the left is from the Pioneer headunit and the colours on the right is the wires from the ford: Red to Yellow/Green - Accessories Blue/White - Blue - Remote wire Yellow - Orange/Black - +12V power Black - Green/Black - Ground Speakers: Purple/Black - Grey - Rear right -ve Purple - White - Rear right +ve White - Black/White - Front left +ve White/Black - Grey/Black - Front left -ve Green/Black - Grey/White - Rear left -ve Green - Purple/White - Rear left +ve Grey - Red/White - Front right +ve Grey/Black - Red/Grey - Front right -ve Bear in mind that the colours on the left are for the Pioneer adaptor, but I believe they are standard colours on most head units nowadays. I've added an extra column to show what each of the other wires does. There are a few wires in the Ford adaptor that don't actually do anything. Just need those four (power, ground, accessories and remote wire). With my remote wire, however, it didn't work, so if you're hooking up an amp and when you switch the head unit on, if the amp doesn't power on, it may be that the remote wire isn't working. I just de-soldered it and connected it to the accessories wire instead and it worked shmick as! Hope this helps. Cheers, Regan
#30 | ||
EuroFordClub
Looks like we're in luck. Check out this site:
http://www.connects2.com/c2search.aspx?catID=16 they have what appears to be an adaptor for the LT radio. The adaptor itself, which wouldn't fit, and looks bizarre, considering they've got the plug connected straight to the aftermarket wires is the one for the Ford Fiesta (CT20FD06). I think the one you guys would need would be the one for the Ford Fusion (CT20FD04). Have a look. Hopefully a solution has been found!! EDIT - 100% guarantee you its the one for the Ford Fusion. See here for an ebay link, cheap as chips. http://cgi.ebay.com.au/ws/eBayISAPI....ksid=p3907.m29
