Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 18-07-2008, 08:14 PM   #1
FTE72
Red is nice Mark.
FTE72's Avatar
Default Query
Hi Matt,
What difference will it make to brake feel if the bore diameter of the fluid entry hole in the banjo bolt is changed, ie: larger or smaller?
I ask as I have a set of 4mm bore and a set of 3mm bore bolts. The 3mm are fitted at present.
Twin T3's
TE 50 #72 Blueprint & TS 50 #105 Blueprint
FTE72 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2008, 11:42 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by FTE72
Hi Matt,
The 4mm would be a better choice but either one won't matter as once you bleed and get pressure in the line it won't matter .
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
