Old 14-06-2008, 04:43 PM   #1
Shinrar
Default Escort MK2 information
Hey fellas,
Im looking into buying a MK2 escort 2 door of one of my mates for cheap and i just got a couple questions about them.
Its got the 2 liter engine at the moment but i was wonder if it possible to fit a different engine in without 2 much troubles. I know a v8 wont fit but i was thinking along the lines of an rb30 or sumthing simmilar. what you guys think?
Anyone know how much the 2doors weigh?
And anything i should look out when i get to look at it closer.
Shinrar is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2008, 05:11 PM   #2
JamesR
Originally Posted by Shinrar
Hey fellas,
v8's will fit, but wont be able it registered.
rb30 is too long.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2008, 08:29 PM   #3
Shinrar
yeah was measuring it up just then.
v8 will fit? wow thats crazy. links to any1 whos done it?
what other engines should i be looking at?
i was checking the car out b4 aswell, not in too bad nic, need alot of TLC and a spray job.
Old 15-06-2008, 12:01 AM   #4
krt10
eskyman
krt10's Avatar
check out this site www.classicford.mine.nu pretty much any questions will be answered there.
a few of the guys have put sr20's in their escorts but not sure about rb30's.
i think 2 doors are about 900-1000kgs. not too sure though
look for internal rust. open the boot and look at the rear quater panels from the inside. rust hides away up there.
who says kents cant be quick
krt10 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2008, 02:28 PM   #5
T3man
T3man's Avatar
950kg kerb weight.
Check for rust in the plenum (middle of firewall directly behind engine) - the rubber drain blocks up easy and the whole firewall can get infected.
Also bottom of "C" pillars is a high risk rust area.
If you want a Nissan motor why not just go and buy a Nissan? LOL
Old 15-06-2008, 02:47 PM   #6
bcr2734
Off tap Truckie
bcr2734's Avatar
so true
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
: Another Power Installment Soon :
1968 KC Bedford
1970 Mk1 Escort GT
1980 Mack Superliner 120t: Project Puppy Dog!
AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5
bcr2734 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2008, 05:20 PM   #7
barneyxr4
hey shinrar...
depends what you want to use the car for??? track/drags/drift/road
i am currently to a sr20det motor into a 78 2dr, and as has already been mention go to www.classicford.mine.nu you'll find everything there
I think the sr is a good conversion and motor is not to heavy parts are everywhere!! and not to much modifying...except engine mounts/trans tunnel and the usual stuff but easy to mod this engine with off the shelf parts.
barneyxr4 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2008, 06:13 PM   #8
Shinrar
hey guys thanks for replys,
ill be picking the escort up in a couple weeks, and start restoring it then. Its not in to bad nick, it needs alot of attention though cus its been sitting for a while. First thing ill do is strip the car down and start the respray process, ive resprayed my current car (vl) which turned out pretty good, but now i know all the tricks and what not to do, should turn out good as.
yeah ive been looking at the sr20det, not bad i reckon. Any1 done a 6cylinder conversion? the cross flow?
I wanna fast street car, not too fast though ahaha.
Old 16-06-2008, 06:21 PM   #9
T3man
T3man's Avatar
any straight six cylinder will be too long - unless you take to the firewall with the oxy. any of the smaller V6s (up to 4.0 litres) will fit pretty easy.
Old 17-06-2008, 05:32 PM   #10
Sterling
if u want a fast street car.. jus stick with the 2.0
a 2.0 with 5 speed and big cam, dual webers, overbore etc etc will easily smoke like commodores and such...
oh and a 4.11 diff aswell maybe.
are you in your p's or past that?
cuz turbo 2 litres are like the poor mans cosworth, but they have power and ltos of it..
an sr20, v6 any large motor with over 150 hp will definately be a weapon.
try to find the equivilant to a holden 3.8 v6, they are sweet compact motors but it would be weird to have a holden motor in a ford wouldnt it.
well good luck with whatever u choose to go with!
ps about the rb motor
i saw a mk1 with a skyline motor once, there had to be a large section cut oout of firewall and the upper section was heavily deepened. nto sure if it affected the interior or not.
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 06:43 PM   #11
Shinrar
Wow thanks sterling.
Yeah im on my p's which means no blue plates!!! :(
but i didn't really care if i couldn't drive it for a while.
Yeah ill seriously consider doin up the orignal 2Litre, i know all about carbies though im more a fuel injection person... guess ill be doin sum research.
how quick you reckon carby 2Ltr can go (heavily modded)? (1/4 mile times)
Old 17-06-2008, 08:21 PM   #12
Sterling
ive seen n/a ones do 12s & 13s
and you can get EFI 2 litres lol
Old 17-06-2008, 09:01 PM   #13
Shinrar
holy crap you serious!!! ahaha 12 sec quarter from 4cyclinder thats crazy.
That would need a heck of alot of mods?
Old 18-06-2008, 06:10 PM   #14
Sterling
um, if memory serves me, it had a 30 thou overbore, large cam, valves done, ports polished, twin webers or dellortors or something, balanced bottem end, light flywheel, 2 1/2 exhaust, adjustable cam wheel, sierra 5spd, and that was in full street trim on street tyres.
the 2.0 is an amazing engine! can take a beating.
do a compression test, see if the engine burns oil, if it ever backfires, how the throttle response is etc.. before considering doing up the motor.
its cuz there so damn light mine is only 950kg or so.
also if u plan on racing it at all, and if its on dirt or such get a lsd or weld ur diff up, the escorts get serious traction problems on dirt and gravel ( if pushed hard )
before anything though, drive the car around alot, i found my standard 2 litre to be entertaining! but still, i upgraded after and got a crane cam, ported head, large valves etc hehe
Old 18-06-2008, 08:33 PM   #15
Shinrar
wow nice
im prolly gunna rebuild the engine straight up with everything i want in it, as ill be respraying it so that will take along time.
hopefully picking it up in 2 weeks, then the stripping begins follow by alot of sanding
Old 19-06-2008, 04:30 PM   #16
Sterling
sweet well good luck with all that!
Old 19-06-2008, 06:07 PM   #17
SeXC
Pushrodosaurus Rex
SeXC's Avatar
Hey fellas,
You CAN fit a windsor 289 or 302.
You can fit a windsor 351, but you will need to put a big hump in the bonnet to allow for the extra height.
you CANNOT put a clevo in there, too wide.
Depending on what state you are in, you may be able to do it, but it will require a LOT of engineering and will be expensive.
Sr20's or ca18 turbos are good,
Cosworth or BDA engine would be better because you can still enter it in cams affiliated races as they are ford motors.
If you dont ever want to race seriously though, i would say put a 13b turbo rotary in it. Have seen a few eskies with them before that pulled low 11's
SeXC is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2008, 07:13 PM   #18
Sterling
rotary swaps are easy to do aswell, because the motor is small in size ( from the outside)
Old 21-06-2008, 09:20 AM   #19
cortina-mk1
Heavy right foot
cortina-mk1's Avatar
there are a couple fitted with blown clevos
some well known ones from
MD conversions in NSW mark at Blacktown 96717508
but as said above cant be registered with them anymore
any firewall mods these days will prevent most conversions from being started
and again if your car has the ADR 27a or higher on the tag then there is less you can do
again it depends on what you are going to use the car for
cosworths are hugely expensive here in Oz
if funds are tight just mod your pinto to your budget
years and years ago at calder street meets a regular runner there in a red mk1 escort
was in the 10.6s running a highly modded turbod pinto owner Nik S.
cortina-mk1 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2008, 10:05 AM   #20
Shinrar
thanks for all the info guys, i might just stick with the pinto cus of P-plate laws and all the crap, id love to stick a little rotary in it but.
Old 22-06-2008, 09:13 AM   #21
cortina-mk1
Heavy right foot
yes this certainly has made it hard now...
Old 22-06-2008, 11:59 PM   #22
TYAFRYA
BEATING GMH'S EVERYWHERE
YOU CAN stick a cleveo in them the eingine bay is wide enough but the firewall needs a masive amount of work
forget doing a 6cyl or v8 coversion
stick with the pinto or a sr both are easy to get parts you wont upest the handling of the car and even a mild na pinto will surprise you
built the car in 18 days whats taking you so long?
TYAFRYA is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2008, 08:23 AM   #23
Shinrar
ahah tru...
Old 23-06-2008, 12:27 PM   #24
P100 Ute
P100 Ute's Avatar
soo true.
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2008, 06:16 PM   #25
Shinrar
AHAHA my god, thats been mutilated!!! must go pretty hard though...
thinking bout a twin turbo 12b or sumthing as they pretty cheap and light
Old 23-06-2008, 10:52 PM   #26
Shinrar
wow just been watching vids of the cosworth in a couple mkIIs my god they fly!!
Old 05-07-2008, 09:52 PM   #27
Rat
Sterling, you are right about the Pinto taking a beating and if done right, the can get some serious bhp! A mate has done most of the work on his Pinto and got 197rwbhp! Twin 45's, Kent cam, electronic ignition.
Rat is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2008, 02:08 AM   #28
clevagexc
clevagexc's Avatar
If you are gonna go turbo rotarty, go 13b, not 12a.....
clevagexc is offline   Reply With Quote Multi-Quote with this Post
