Old 13-03-2008, 01:17 AM   #1
Shaq42
Default Engine making ticking noise
Hey just a quick question my engine is making a ticking noise whenever i drive. Its a ford falcon au forte series III. Just wondering if anyone has had this problem before and how they fixed thanks.
Shaq42 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 01:34 AM   #2
HLC
Audi S3
put some oil in it.
noisy lifters are common. but if the ticking is loud, then you are probably severly low on oil.
but if oil is good, tighten your header bolts.
Old 13-03-2008, 02:51 AM   #3
GK
Walking with God
GK's Avatar
Shaq, we need some more info. What revs does the sound occur? Is it the same volume, or does it get louder or softer under certain conditions. Does it do it at idle? Does it come from more from one side of the car than the other?
Does it make the noise under braking? Does it make the noise when turning?
Is the noise high or low or medium pitch?
The more info you give us, the more we'll be able to help point you in the right direction.
Cheers,
GK
BTW, just in case your oil is very, very low, check it first thing tomorrow!
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-03-2008, 03:07 AM   #4
Shaq42
hey sorry the noise is constant all the time when the car is on. when i rev it ticks to the revs. eg if i go fast it'll tick fast and when i slow down it'll tick slower. when im idle it'll tick as well. ill check my oil in the morning thanks for the help! hopefull it helps
Old 13-03-2008, 09:25 AM   #5
JoesAu
JoesAu's Avatar
is the noise seem to be coming from the right hand side??, my car was doing the same thing a couple of weeks ago so i changed my header gasket and it fixed it.
At idle that will be your lifters! check your oil? how old is the oil more importantly?
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 10:41 AM   #6
FGII-XR6
FGII-XR6's Avatar
if your lifters are ticking make sure the oil you're using is not heavier than specified . i was using a slightly heavier oil and had ticking lifters i went back to the correct spec oil and fixed the problem
[SIGPIC][/SIGPIC]
Rides:
Old 13-03-2008, 01:24 PM   #7
Burley
CRE.87V
is it ur injectors???? mine was said to be lifters, these where replaced months ago noise is still there....mine is coming from injectors and fuel rail....dont know wat this is
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 06:51 PM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
It would be the Oil .. I bet !
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2008, 09:37 PM   #9
Shaq42
it was the oil ! thanks for helping me out everyone, got scared for a moment hahaha. Cars running smooth now
Old 13-03-2008, 10:18 PM   #10
GK
Walking with God
GK's Avatar
The prize goes to HLC! LOL!
Glad the problem is sorted.
GK
Now gone!
On LPG
Old 13-03-2008, 11:08 PM   #11
HLC
Audi S3
GK
yeah i did this on my car about a month ago
tightened up the headers and the ticking went.
about 2 days later it was back and getting worse. i'd checked the oil about a month prior and it was sweet. so i didnt think to check it again.
i checked it, and hardly any oil in there... oops filled er up and all is well!
Old 29-11-2020, 01:27 PM   #12
chatty2387
Default Re: Engine making ticking noise
My BF dedicated gas has just started ticking when cold but when it hits operating temp the tick goes. Any ideas? I initially thought oil but al it good.
chatty2387 is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2020, 10:03 PM   #13
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Engine making ticking noise
As this is the AU section you might be BA/BF section.
UK
