Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club. |
07-03-2008, 09:03 PM | #1 | ||
Hi guys
i have a XY falcon wagon and im just wondering if anyone has actually put in an XF steering box before. I just want to find out if its possible. Thanks Melissa |
07-03-2008, 09:10 PM | #2 | ||
Giddy up.
Have a read off this thread,
http://www.fordforums.com.au/showthread.php?t=106569 |
06-05-2008, 01:17 PM | #3 | ||
Hi the XW part number which has been used until recently is the same as a XF box incl pitman arm . yes you can bolt it right in . will need new flexible coupling on end of st column .I have a complete unit that came of a 6 cyl good cond just ft it up Justin. contact jamjay65@yahoo.com.au
06-05-2008, 01:38 PM | #4 | ||
XW-XY is different mounting to XF. See post above for link .They will not bolt up without mods to chassis.
07-05-2008, 03:26 PM | #5 | ||
fat289
2 holes line up the other dosent
do up a bolt in the 1 thats out cut it off flush then drill & tap in the correct position Easy as !!!!!!!!!!
I'm just having a great Falcon time , thanks for asking dumba$$ XRGT XP ute 351w Toploader 99 Springer softail XW Fairmont 302w / c4 col shift 58,000 miles |
11-05-2008, 11:03 AM | #6 | ||
I have an XT falcon. It has XF power steering. It was like that when I got it so I don't know what mods (if any) were done to it. You are welcome to come and have a look if you like.
John |
04-11-2020, 08:46 PM | #7 | ||
Hi guys, I have an XY 351 Cleveland C4 auto sedan and I have installed an XF power steering box, it works perfectly but I don't have enough clearance between it and the extractors. Does anyone know of a set or brand that will clear the steering box .
